Normal coolant temperature
Old Dec 15, 2013 | 03:26 PM
SRQStingray's Avatar
SRQStingray
Default Normal coolant temperature
OK, this may be a dumb question, but at what temperature should the coolant be in normal driving? Mine is at 220. I assume since it is midpoint on the gauge, it is where it should be.
Old Dec 15, 2013 | 03:30 PM
-CM-'s Avatar
-CM-
That's the normal for my analog gauge, also. But I think the digital pocket gauge reads differently. If I ever get to drive it again (snow everywhere) I'll double-check it.
Old Dec 15, 2013 | 03:32 PM
VETJAZZ's Avatar
VETJAZZ
Mine read 208-212 on my 3 day, 1,800 mile trip home from the museum. (Got home yesterday!)
Old Dec 15, 2013 | 03:35 PM
SRQStingray
My digital reads about 10 degrees lower, 210.
Old Dec 15, 2013 | 04:16 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Begs the question - which one is right?
Old Dec 15, 2013 | 04:20 PM
Mad*Max's Avatar
Mad*Max
Old Dec 15, 2013 | 04:22 PM
cb98coupe's Avatar
cb98coupe
The one that is right is the one that makes you feel better .....
Old Dec 15, 2013 | 04:37 PM
Patman's Avatar
Patman
Does anyone know what thermostat the LT1 has in it? Because with both my C5 and my C6 the coolant temperature would run at between 190-194 at a steady highway cruise (higher in stop and go traffic though), but both of them also came stock with cooler thermostats than other GM engines. But perhaps the LT1 is running a hotter one now?
Old Dec 16, 2013 | 09:58 AM
pcguy2u's Avatar
pcguy2u
Even our ZR1 runs at 192 normally.
To Normal coolant temperature
