front camera that will record
Old Dec 19, 2013 | 09:03 AM
flyboyslc1's Avatar
flyboyslc1
Default front camera that will record
I saw AFORAND's post regarding a front camera. I didn't want to hijack his thread, but I have wished several times that I had a front camera that would record Oh, say an hours worth of driving time. Several times my Corvettes have been struck by debris or other such things falling off of trucks. It would make it easier to collect damages from the culprits when this happens. The police already have something like this.
I don't want something dash mounted like I think they have. Is there anything already out there that I am not aware of?
steve
Old Dec 19, 2013 | 09:12 AM
stevelischynsky's Avatar
stevelischynsky
steve
There are many dash cams available, mostly from Korea. You need hi-def. No lights and no built in view screen is required. Expect to pay around $180. I have 2 installed on my trailblazer, one in front and one in back.
Old Dec 19, 2013 | 10:35 AM
SpartyGW's Avatar
SpartyGW
Mobius is under $90 from Amazon.
Old Dec 19, 2013 | 10:39 AM
Greg00Coupe's Avatar
Greg00Coupe
Some cameras will record front and back........ like most things it comes down to dollars.
Old Dec 19, 2013 | 10:56 AM
Blue Lagoon's Avatar
Blue Lagoon
Default Recording
I have used this camera in an earlier life. Worked flawlessly. What makes it fit your wants about road debrs damage, IMO, is it is "on" but not recording all the time.
There is a setable option that allows you to hit the record button and it will start the recording (if I remember right) either 30 secs, 60 secs, or 2 minutes prior to hitting the button. It is always saving that amount of time to flash memory, and only recording it when the record button is hit. So if a refrigerator falls off the truck in front of you, hit the record button and the 2 minutes prior to and all after are recorded, until stopped. Cost is high ($4,295), but pretty small footprint.
The ability to record what happened before you hit record is the awesome part.
http://www.digitalallyinc.com/DVM-500PlusSystem.html
Mike
I am in no way, shape, or form associated with this company.
Old Dec 19, 2013 | 11:15 AM
sprtplt's Avatar
sprtplt
What to look for (and is hard to find) is one that will come on with the car
(switched 12v plug, and just starts recording without having to press any buttons) and automatically just keeps overwriting the SD card as needed.
I have found this but not in anything with good enough resolution.
Old Dec 19, 2013 | 12:13 PM
SpartyGW's Avatar
SpartyGW
Mobius will loop and keep overwriting. Supports 64GB micro sd. You can wire it to +12VDC into your fused ignition.
Look at dashcamtalk.com for more options.
I have no financial interest in recommending the Mobius. I own one though.
Old Dec 19, 2013 | 05:22 PM
stevelischynsky
I agree, look at dashcamtalk.com for lots of good info.
The set up that records front and back typically do not record at HD when both cameras are used. That is why I opted to get two separate but identical cameras. You need HD to read plate numbers.
Also the cameras need to be put in place and forget..i.e. no buttons to push at any time. Records over the oldest files.
Also a good suggestion is to get the power supplies that will disconnect the camera when battery voltage drops below 11,8 Volts so it doesn't drain your battery.
Include GPS and motion and shock recording for when it is parked and someone hits the car. It will save a few minutes before and after the event. I have the ITB HD black box that has all of these features and seems to work fine with the power supply.
To front camera that will record
