Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- Corvette: How to Remove Visor Warning Label
Step by step instructions for do-it-yourselfers...
Visor Warning Label Removal - with pics...advice needed
Received 9,531 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
First, I read through a previous thread regarding visor warning label removal and got some ideas from that thread as well as other online sources. At this point, I'm not 100% satisfied with the results, but I'm going to figure out how to get it perfect, or close to it. After using several suggested methods, I found the following to work best on the C7 black visor fabric.
Step 1: Decide if you really want to remove the label or not. Some see no reason to, others think they are an eyesore, while still others think it's enough that Big Brother tells us that we all have to wear seat belts, let alone require manufacturers to put air bag warning labels on our cars. Now, I personally think Big Brother needs to figure out a better warning label for two seaters since they would probably rather I not place my child in the rear cargo area of my C7 (see warning label bullet number 2).
Step 2: Using a hair dryer on high heat, begin blowing hot air on one corner of the label. Once you've done this for a few seconds, begin to pull the corner of the label from the visor.
Step 3: Continue blowing hot air along the back edge of the label as you slowly pull the label off the visor. If your fingers get hot, put some gloves on...or suck it up and see how hot you can let your fingers get before you switch hands. The following photo shows what the visor fabric looks like after removing the warning label prior to any treatment.
Step 4: At this point, there are several ways to remove the glue that has remained behind on the visor fabric. I found that a stronger adhesive remover worked best. I used 3M Adhesive and Wax remover. Spray the adhesive remover on a clean cloth and work it into the surface of the visor fabric. As the adhesive begins to come off the visor, use other sections of the cloth as the adhesive will adhere to the cloth you are using. WARNING: Using too much adhesive removed will release the adhesive holding the visor fabric in place. It's better to begin by using very little adhesive remover than to begin with too much.
Step 5: Once you have the glue cleaned off, spray the area with a mild water and soap solution to clean the adhesive remover from the fabric. Use another clean cloth to clean and dry visor.
EDIT: At this point, I was not initially 100% happy with the result. The next two photos show what the visors looked like at this point.
Driver Side Visor
Passenger Side Visor
So I went back and used a mild adhesive remover once again (Elmer's Sticky Out). This time, I used the hair dryer to blow hot air on the surface as I rubbed the adhesive remover over the fabric. I could see that using the hair dryer with the adhesive remover was making a difference! I then used a wet rag and rubbed the fabric quite a bit to remove all remaining adhesive and to raise the fabric in a way that matched the rest of the fabric on the visor. The next two photos reveal the finished product. And I think I can live with this.
Driver Side Final Result
Passenger Side Final Result
Step 6: Enjoy your warning label free visors!
Thanks to those who posted thoughts or experiential advice between the time I first posted and the time I was able to obtain satisfactory results.
Driver Side Visor
The following 7 users liked this post by E.T.D. Corvettes:
767guy (01-01-2017),
bjones7131 (02-08-2017),
Former USMC (07-13-2017),
garymilgrom (05-06-2016),
Hopper12 (02-08-2017),
and 2 others liked this post.
The labels make a good point! Make sure to put your child's car seat in the backseat of your Corvettes, people!
The following 3 users liked this post by w0rM:
other brother daryl
I bought a sheet of 3M Dinoc faux carbon fiber stick on material. Cut two rectangles, radiused the corners, stuck them on. No mess no fuss. The look is pretty decent.
We replaced both C6 visors when glue starting dripping from them. Looked like icicles dripping from a roof. Dealer said they had gotten so hot the inside adhesive material turned liquid. It gets pretty toasty during the Tucson summer and our convertible visors were exposed to the sun a lot. Not excited about getting out the hair dryer because of this.
I have the microfiber uppers, which includes the visors. (I think the order code was IWE.) When i removed the warning labels there was so little noticeable residue that I was finished at that point. Highly recommended!
drsweet2006 (10-10-2017)
2015 C7 of the Year
I've seen the faux carbon material, but I'm really looking for a cleaner look. Thanks for the input though.
http://www.rpidesigns.com/shop/item.aspx?itemid=3171
I had something like this on my C6, they were fabric.
my suggestion is to get fabric thats as close to the interior color and texture- just cover them.
I was thinking this yesterday when I drove mine, the stickers are obnoxious and too bright
Yeah, hate those stickers. Wonder if there are aftermarket places that will make a "glove" for visors or a complete replacement. It's completely stupid in the first place--that's an absurd location.
Someone on the forum suggested using Di-Noc CF vinyl. Just cut it to the proper size and stick it on. I think it might have been Glen E? Amazon might have it available also.
http://www.metrorestyling.com/3M-DI-...p/dinoc421.htm
hope this helps.
hope this helps.
2015 C7 of the Year
Yes, Glen went that route. Just not the look I'm wanting...looks like one just tried to cover something up, which is what it is.
Covered the airbag labels on my new C7 sun visors with flat black/cashmere lettered Corvette logo labels from Decal Dave. Goes on right over existing warning labels, and, covers them completely. With my Kalahari interior it looks just like it was designed for the interior of my C7, and, looks sharp. Cost was only $19.99 for both decals. Took 5 minutes to install.
Oops!, I see that now as I read further into the thread. Apologies
Glen, I dont remember seeing any of your visor pics and was wondering how the Di Noc turned out?.
BTW, I used your detailing guide on my wife's Accord. I used the Blackfire Polish and Seal followed up with the Crystal Seal and the car looks brand new. Lots of rain in the NW this time of year. My wife commented on the fact that the car seems to repel the dirt and grime and retains its luster.
Thanks again!
Thanks again!
there is another thread here:
http://forums.corvetteforum.com/c7-g...-stick-on.html
glad you like the products - now just wash and crystal seal every 2-3 months...
2015 C7 of the Year
I went back and used a mild adhesive remover once again. This time, I used the hair dryer to blow hot air on the surface as I rubbed the adhesive remover over the fabric. I could see that using the hair dryer with the adhesive remover was making a difference! I then used a wet rag and rubbed the fabric quite a bit to remove all remaining adhesive and to raise the fabric in a way that matched the rest of the fabric on the visor. The next two photos reveal the finished product. And I think I can live with this.
