Lowering on stock bolts - Instructions and Photos
#381
None that i know of. I lowered it went back to the dealership. They told me my alignment was off and adjusted it back to factory specs. That's was it....
#382
I have a question. Sorry I didn't read through all of the 20 pages here to see if this was addressed before. What I don't get is why do this? I mean the vette is already a bottom feeder and there are numerous threads about how to protect your car from bottoming out on things like driveways. Looking at the before and after photos I don't see that much of a difference. So what's the purpose really? Cosmetic? Or are their performance advantages? And after you do this what additional things do you need to do to avoid scraping the bottom of your car?
#384
#385
I have what may seem like a dumb question but when turning the bolts they rise I get that but at what point do you stop? Will they actually come out if you continue to turn them? I apologize for the ignorance but curious as I don't ant to mess anything up.
#386
In a lot of the after photos I think people are taking the picture too soon, before the suspension has had time to fully settle as I have found it takes about 500 miles after an adjustment before it fully settles. With just turning the bolts alone you should see almost an inch of drop, but if you cut the bushings you can see another 1/2" or so. I've got the bolts on the front of my C6 all the way down, and a portion of the rear bushings cut so mine definitely looks a lot lower than stock. That's the main purpose, the stock ride height shows far too much gap in the wheel well and a lot of us just find that look awful. I have had my C6 lowered for about 3 years now with no problems, tire wear is still perfect (I had mine aligned) and no suspension problems. You do have be careful over speed bumps and entering some driveways but it's not that much of a problem.
#387
They will not come out. they will bottom out and stop when you can't go any more.
As to why...
Love the lower look, gives it a better attitude.
I have had 0 issues bottoming out....
#389
There have been some who have been able to swing an alignment (on GM's dime) before 7500 miles, but the bolts and lowering them don't have anything to do with it.
#390
The supposed <7500 mi free alignment is what i'm referring to. Post-lowering it may need an alignment.
owc6 (06-23-2017)
#391
My car had very little miles when I did it the dealership I purchased it did it while I was having it updated for a a few things......
#392
Post-lowering, mine needed one badly, and 500 miles later it needed an other (I could feel it starting to pull to the right as the miles went on), but has been good since. I don't know right off the top of my head but ~ 20,000 miles.
chronage (06-23-2017)
#393
Did you just ask them to check the alignment for some arbitrary reason? I assume you didnt say "I lowered my car, align it for free please"
#394
Just told them car felt funny going down the highway. Thet were more than happy to look at it. Its factory bolts. Even if you lowered it they can bring it back to the correct settings.
#395
Read a lot of this thread before I did the lowering. I was going to do it regardless of whatever concerns a lot of people had. My 16 Z51 non mag ride car was all over the place in terms of where the bolts were from the factory. I mean like it was a totally noticeable difference in how each bolt was positioned.
IF your on the fence about it at least just take a look under the car and make aure your bolts are all at the same height.
I left a few threads on the driver side front n back so when I get my fat *** in the car it won't be tipping to one side (j/k) but the thought did cross my mind.
Overall your totally safe on the stock bolts fully lowered. My 2014 EVO X totally stock suspension has less ground to front bumper clearance THEN THE VETTE thats fully lowered.
A few beers and 30 min of your time should do the trick. Honestly you guys, too much wheel gap is just nasty!
#396
Lowered my Z51 w/MRC all the way down this morning and couldn't have been easier! Working alone, I had all 4 corners done in 15 minutes. Looks great will no ill effect to ride quality.
Thread I've since made, I used hockey pucks rather than jacking pucks to lift the car: https://www.corvetteforum.com/forums...key-pucks.html
Did you only use one jack and one puck and go from wheel to wheel?
#397
be careful though man, I dropped mine all the way and the little air deflectors scrape on every damn thing. Driveways will make you cringe. You will hate speed bumps.. just to give you a real world idea of how low this actually goes...
that's pretty low bro. That cancer stick box barely clears. It might become a real annoyance. I'm always thinking I'm ripping off the front of the car no matter how careful I am.
To date no bumper damage, but I cringe every time.
#398
Scraping those rubber air dams doesn't matter. I'm lowered all the way on stock bolts and it's no big deal.
#399
Also, just to add.. it makes it a hell of a lot easier if you have a set of these
countless uses. Everyone should have a set, period. It just takes off so much time from super simple jobs. And it inexpensive. Seriously
#400
do you have a front lip on the car? A lot of people add them after the fact and SOME are almost as low as those rubber deflectors... just saying. Thinking about the future.
