Lowering on stock bolts - Instructions and Photos
#461
Received 9,518 Likes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
pnsnkr (03-16-2018)
#465
Is that closer to 3 3/4" or 3 1/2"? Is it just lowered on stock bolts or is that with the bushing cut down as well?
Asking as the photo seems to be on a bit of an angle.
Deicide (04-04-2018)
The following 2 users liked this post by C7s:
BostonVette (05-12-2018),
ilkSurfer (08-08-2018)
#472
Just did this today although this before pic is from a few weeks ago.
I got 1/2 inch lower in the rear and 3/4 inch lower in the front on stock bolts maybe is will settle a bit more in the coming days? if not iam fine with it....not a huge overall difference in appearance but i can tell there is less body roll in general and it does look better.
Before ( 3 weeks ago )
AFTER (today)
AFTER (today)
#473
Has anyone else had unbalanced tire wear issues after lowering the C7 on stock bolts? I got an alignment done(at the dealership) right after I lowered the car and another a year later. Both reports said they were fine. I'm having uneven tire wear on the inside of all tires now. Prior to lowering I had no wear issues and the OEM Michelin ZP tries wore evenly.
#479
2015 C7 of the Year
I had no idea the photos had disappeared, but fortunately I found them on my laptop (except for the before and after of the rears). I loaded the photos again on the first post.
#480
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
You have to tell most what you want, i.e. if you have no other thought the centerline on all specs. Toe is also important for tire wear and should be set close to zero, which is about where the GM centerline is.
Note, I'd forget trying to specify rear caster if at a dealer as many do not have the measurement tool and even IF they do they might not have the skill to use it! Those are a different set of adustments and there are forum posts where it was screwed up and caused significant handling problems. If Tracking, go to a shop who has the experience and skill to measure and set rear caster as you'll probably want a camber outside the GM spec anyway. Some Tracking specs are published on the Forum.
This is the GM C7 alignment specs:
