Supercharger Issues
Old Jan 22, 2014 | 03:36 PM
tkbigsky's Avatar
tkbigsky
Default Supercharger Issues
Spent the week at Barrett Jackson in Scottsdale and talked with a lot of engineers and performance companies re: Superchargers for my new C7. It was explained to me that there are some architecture issues in the current motor that still need to be addressed by GM and not to do anything to the motor until that service is done to avoid warranty issues. The only guys stating they had a working model was Hennessey and their car was I believe Vic Edelbrock's personal car and no production parts were available. LPE seemed real straight forward and said hold off due to the above issues. It's also interesting to note that the Hennessey C7 that ran 200 was also given a big shot of nitrous for that run. Anyone hearing this same information?
Old Jan 22, 2014 | 04:12 PM
senah's Avatar
senah
what you mean by an architecture issue that can be done by merely completing an engine service?
Old Jan 22, 2014 | 04:42 PM
jkcam6017's Avatar
jkcam6017
Did you talk to Callaway? They don't mention waiting for issue resolution in their website?
Old Jan 22, 2014 | 07:54 PM
LT1xL82's Avatar
LT1xL82
What does " some architecture issues in the current motor " mean?
Old Jan 22, 2014 | 09:54 PM
jamesw95's Avatar
jamesw95
On the video you could see Mr Hennessy with the switch in hand hitting the NOX. As for GM adressing architecture issues for aftermarket superchargers, I don't think so.
Old Jan 22, 2014 | 11:52 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
Didn't Edelbrock have an Eforce setup on display for SEMA? Still waiting for any official specs and vids.
Old Jan 22, 2014 | 11:53 PM
Callaway Chris's Avatar
0Callaway Chris
Former Vendor
Thanks for the mention @ www.callawaycars.com
Old Jan 23, 2014 | 02:28 AM
Jontall's Avatar
Jontall
The only architecture issue that I know of is the direct injection fuel pump being too small for forced induction. This problem has been addressed by GM with the new larger Z06 direct injection fuel pump, but the pump and associated parts are not available yet and will probably be expensive.
Old Jan 23, 2014 | 08:56 AM
BRCC's Avatar
BRCC
I would think if one puts a supercharger on a C7 the drive train warranty is out the door with GM, but the supercharger provider might provide some form of warranty.
Old Jan 23, 2014 | 09:16 AM
Blown-C7's Avatar
Blown-C7
I am having a blower installed at Hennessey next week...no mention to me of any architecture issues.
Old Jan 23, 2014 | 09:20 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
lots of C7's already with blowers installed and on the streets....guess the engineers missed the memo
Old Jan 23, 2014 | 09:46 AM
mjw930's Avatar
mjw930
Just because they are on cars and on the street doesn't mean they will live.
Remember, GM must produce an engine package that will last through their 5 year, 100,000 mile powertrain warranty, the aftermarket doesn't have such constraints.
Engineering is a very strict discipline, one that not all aftermarket vendors follow.
And yes, bolt a supercharger onto the motor and your powertrain warranty isn't worth the paper it's written on. Don't bother quoting Magnuson-Moss, it's really easy for them to deny it and a hell of a lot harder for you to fight. Most arbitrators will side with the manufacturer when the add on part it a power adder.
Old Jan 23, 2014 | 10:41 AM
tkbigsky's Avatar
tkbigsky
Didn't see Callaway in attendance at Barrett Jackson. There is the issue with the fuel pump being driven by the cam and lack of pressure. Some have gone with additional electric fuel pumps to help. Seemed like the real concern was detonation which apparently would not be pretty in those engines.
Old Jan 23, 2014 | 11:06 AM
JoesC5's Avatar
JoesC5
I'm in the "wait and see" camp on this issue. GM must have felt that there was an issue with the fuel supply, as they designed and built a special larger displacement fuel pump with higher fuel line pressure to handle their Z06's 625 HP(est).
Old Jan 23, 2014 | 11:32 AM
Kingspoke's Avatar
Kingspoke
Good point!
Old Jan 23, 2014 | 11:56 AM
m3incorp's Avatar
m3incorp
That switch was supposedly to take a snapshot of the speed readout when it reached 200 mph.
Old Jan 23, 2014 | 12:42 PM
C7pimp's Avatar
C7pimp
That doesn't have ****-all to do with the LT1.
Engineers do not design fuel systems to run even close to 100% capacity.
The Z06 fuel system was design with the idea that it's not running even close to full capacity at WOT, full boost at high rpms. The LT1's fuel limit was not in any way, shape or form given any weight into using a larger capacity fuel system in the Z06. Anybody with a brain would realize that from day 1 of considering both engines, that their fuel system capacity requirements were completely separate and independent from the get-go because of their target outputs.. The Z06 fuel system will probably support near 800whp without modification.
The LT1 fuel system is proven to run without hiccup at 600whp. That's probably right near cold-**** max for the fuel system. If you max the system and run out of fuel, the car should hopefully go into limp mode/fail safe mode when it detects insufficient fuel supply, hopefully before the engine burns up.
No offense, but that is an ignorant assumption.
To Supercharger Issues
Old Jan 23, 2014 | 01:11 PM
JoesC5's Avatar
JoesC5
Don't tell me that I'm ignorant. Take your engineering degree and wave it in front of Tadge's face and tell him that he is ignorant, as he supervised the design of the Z06's fuel system with it's larger displacement fuel pump vs the LT1's smaller unit. Oh, and while your strutting your tail feathers, shove your engineering degree in the face of Jordan Lee and call him ignorant.
Old Jan 23, 2014 | 01:31 PM
OddJob1971's Avatar
OddJob1971
St Jude Donor '14
There are no issues with the motor and fuel system up to about 600hp. This has been proven in the several builds done by LMR, Vengence, ECS, etc. If you want to go above that there will basically be two options. Go with a larger fuel lope cam which LMR, Vengence, etc have done or wait for an aftermarket or Z06 fuel system upgrade. Yes your warranty will be gone with adding an aftermarket supercharger. Some care about that, some don't.
Old Jan 23, 2014 | 01:46 PM
JoesC5's Avatar
JoesC5
I guess there is also no issue with the LT1's crankshaft, rods and pistons since the aftermarket has them in their 600 HP engines.
Wonder why the dumbass GM engineers changed the crankshaft, rods and pistons in the LT4? Maybe just to run up the cost of the Z06 as they apparently have no need to be in the LT4 since an aftermarket supercharged LT1 doesn't need them. LOL
