battery package
Old Jan 25, 2014 | 07:29 PM
slvr 07's Avatar
slvr 07
for what its worth. i bought my tender on ebay for 30.00. for those who want to save 70.00
Old Jan 25, 2014 | 07:30 PM
Glen e's Avatar
Glen e
Or just buy a batt disconnect switch, yes, that will work fine if batt is fully charged.....
Old Jan 25, 2014 | 07:35 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
'cept you lose window indexing, seat, mirror and radio mems every time, no? Unless the memories in the C7 are non-volatile?
Old Jan 25, 2014 | 08:05 PM
Glen e's Avatar
Glen e
I have disconnected mine about 5 times in the past 3 days, working on my steering wheel - twice overnight. And all I lose is what radio station it comes on at, (not the favorites) and window indexing - which means you roll the window down and back up. Everything else is non volatile...
that's it ...disconnect is very viable...But only if you are 100% charged...and also, remember before you shut down for the winter, you save your settings via USB, and everything works with a update in 15 secs when you reconnect...
Personally, I'd throw the whole ctek charger thing out the window....and install this:
Amazon.com: NOCO ID220S 6V-24V 125 Amp Battery Disconnect Switch: Automotive Amazon.com: NOCO ID220S 6V-24V 125 Amp Battery Disconnect Switch: Automotive
Old Jan 25, 2014 | 08:06 PM
KenHorse's Avatar
KenHorse
I have disconnected mine about 5 times in the past two days working on my steering wheel - twice overnight. And all I lose is what radio station it comes on at (not the favorites) and window indexing - which means you roll the window down and back up. Everything else is non volatile...
that's it ...disconnect is very viable...But only if oyu are 100% charged...and also remember before you shut down for the winter, you save your settings via USB and everything works with a update in 15 secs when you reconnect...
With the cost of EEPROM being so cheap and write cycle limits being so much greater now, that is good to hear
Old Jan 25, 2014 | 10:24 PM
C7Joy's Avatar
C7Joy
Originally Posted by slvr 07
i used a battery tender for 3 winters, in upstate n.y. never had a dead battery. now that i know what the battery package is. its the battery tender for me. thanks for all the replys...
My C6 is on it's 4th upstate NY winter with a battery tender using the cigarette lighter socket. No issues ever. I don't bother with it during the summer months because I am driving my car, but the tender sure helps when there is down time.
BTW, I did order the battery protection package with my C7. Hopefully the Stingray will be around about the time winter departs.
Old Jan 25, 2014 | 11:20 PM
Jbal's Avatar
Jbal
Ken; Thanks so much! Really Appreciated!
Wish You The Best! Jerry
Old Jan 25, 2014 | 11:41 PM
BIG Dave's Avatar
BIG Dave
I've used the CTEK 3300 for years and it works great! It's sealed for outdoor use, features reverse-polarity protection, and has Desulfication, Bulk Charge, Absorption and Pulse modes.
Available through this supporting dealer: http://www.southerncarparts.com/ctek...300-p-468.html
Old Jan 26, 2014 | 08:14 AM
LIStingray's Avatar
LIStingray
What is the difference between the CTEK 3300 & 4.3? Retail (Amazon) there seems to be only a $3 difference in price? In looking at the specs the 4.3 seems better - am I missing some advantage the 3300 has?
Old Jan 26, 2014 | 09:22 AM
BIG Dave's Avatar
BIG Dave
The 4.3 is a new model and (from what I remember) wasn't available when I purchased my 3300 a few years ago. You are correct, the 4.3 does appear to have better specs. Given the choice, and being similarly priced, I would go with the 4.3.
Old Jan 26, 2014 | 10:47 AM
coupeguyz51's Avatar
coupeguyz51
Originally Posted by WKMCD
I actually changed my mind on this after visiting Mike Furman at Criswell's where mine will be ordered in the next few weeks. According to Mike, there are 18 things on the C7 that continue to draw power when it's just sitting in the garage. For $100, it's really a no-brainer for me. Plugs into a power tap/cigarette lighter thingy in the right rear above the battery.
How do you run the wire to the external power source? Can you just gently close hatch on it or do you have to run it out a window?
Old Jan 26, 2014 | 12:04 PM
GTFD2's Avatar
GTFD2
Just close the hatch on it.
Old Jan 26, 2014 | 12:08 PM
  #33
georgied's Avatar
georgied
Default Freebee
I noticed when I bought mine that it didn't come with the battery protection package on the sticker. When I picked the car up, however, the charger was in the well in the rear of the car. Interesting.
Old Jan 26, 2014 | 01:02 PM
  #34
coupeguyz51
Old Jan 26, 2014 | 02:24 PM
  #35
doug doo wop's Avatar
doug doo wop
I payed $8.00 for mine and have used them outside for over 12 years for my C5's and never had a problem. Just hook the two terminals onto the battery and didn't latch the hood and put my car cover on; can't get any easier or cheaper then that!
Old Jan 26, 2014 | 03:16 PM
  #36
RedC5's Avatar
RedC5
Yup using a harbor freight on C5 right now. Never any problems charging Red Tops
Old Jan 26, 2014 | 08:41 PM
  #37
Dave80C3's Avatar
Dave80C3
Just ordered the CTEC 4.3 for 57.63, which is a good deal less than the factory option which is a less expensive CTEK 3000.
Old Jan 27, 2014 | 09:59 AM
  #38
doug doo wop
Yes, Harbor Freight, couldn't think of the name; have two of them.
Old Jan 27, 2014 | 10:48 AM
  #39
Harry2's Avatar
Harry2
I have been using my Deltran Battery Tender Plus for each of my previous three C6's with excellent results through the long MN winters. I plan on ordering the cigarette lighter adaptor and continue using the same battery tender system for my future C7.
