Accelerator pedal
Old Jan 27, 2014 | 01:56 PM
RicK T's Avatar
RicK T
Originally Posted by Nicky43
For me it's not so much that it is stiff, it just seems you have to push it further than you'd expect to get the intended response from the car. It's as though the potentiometer doesn't change the setting much for the first inch of pedal travel. My guess is that is intentional so the un-experienced won't get in the car and put way more power to the wheels than they intended.
Originally Posted by Turbooo2u
I've noticed that the first 3/4 inch of pedal travel doesn't get you much acceleration. Must be some torque management that can be tuned out.
I'm sure that's just the slow throttle map, same as C6.
That is what Chuck CoW's "CoW Booster" tune and add-on devices like Sprint Booster addressed on the C6. Apparently some canned and custom tunes can do a little with it too.
Old Jan 27, 2014 | 03:40 PM
r1owner's Avatar
r1owner
Maybe it just feels different cause it's hinged at the bottom?
Old Jan 27, 2014 | 04:05 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Originally Posted by JerryU
Apparently they now use non-contact devices such as Hall effect sensors, Inductive sensors. Etc! Things that don't wear.
Well then I say flux it!
Old Jan 27, 2014 | 04:39 PM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
It depends on the setting. In weather it is supposed to be slower to help avoid traction problems. I drive all the time in Sport so have not tried that setting. Could try tomorrow were are supposed to get our first snow in 2 years! About 2 inches with ice and sleet. No way the Vette is going anywhere!!
Just to set the record straight it is apparently not a potentiometer, they are using devices like a Hall effect sensor. There are various types but basically a magnet is moved past a coil providing an electrical signal. That is what the transmission uses to define which gear you’re going into for the rev matching. Back to the gas pedal, there are no contacting or rubbing parts as there would be with a potentiometer. Therefore the only resistance should be a spring to bring the pedal back or a carpet causing binding . The amount it moves the air intake butterfly is controlled by the computer so for some settings it is purposely made slower.
Old Jan 27, 2014 | 04:46 PM
rsvette12's Avatar
rsvette12
Just called service dept where I bought the car (Macmulkin) and they said it is what it is hmm, nothing they can do and have not heard of any recall on this so might have to live with it, when the weather gets better I will look into it further but right now its locked in public storage.
Old Jan 27, 2014 | 04:47 PM
HolyRoller's Avatar
HolyRoller
Originally Posted by KenHorse
Potentially.....
oh bad. But a good one.
Old Jan 27, 2014 | 04:49 PM
Glen e's Avatar
Glen e
It depends on the setting. In weather it is supposed to be slower to help avoid traction problems. .
In product training they call the pedal getting "longer or shorter" - the eco,weather and tour are longer settings for the pedal (less responsive), the sport and track are shorter travel settings (more responsive).
Old Jan 27, 2014 | 04:56 PM
rsvette12's Avatar
rsvette12
I have only used sport mode the few times I have driven it, dam weather, still luv this car
Old Jan 28, 2014 | 06:58 AM
pgway's Avatar
pgway
But there is a rheostat!
You don't know the difference between a rheostat and a potentiometer?
There is definetely no rheostat on a corvette!
Old Jan 28, 2014 | 07:06 AM
JerryU's Avatar
JerryU
That is a very good description, it should get longer and shorter as far as how it responds, but not stiffer as this thread started. Since they are apparently using non-contact sensors, if it is to “stiff” there is something causing friction or a carpet, etc. in the way.
Old Jan 28, 2014 | 11:36 AM
Nicky43's Avatar
Nicky43
That's exactly what is happening and I don't like it. I can understand their logic behind this feature but I personally don't like when they do anything that changes the amount of the responses to my inputs that I am expecting.
For example: I drove all week on Eco. On Saturday went out in Sport and ended up leaving rubber because the pedal was shorter and I got more response than I was expecting. I'm sure I'll get used to it so no biggy.
Old Jan 28, 2014 | 11:45 AM
KenHorse's Avatar
KenHorse
Not to be picky but I hold a BSEE. I know the difference
Why must you be so resistant to the current situation? I would hope your capacity for humor would have realized that there's no place like ohm
Old Jan 28, 2014 | 01:17 PM
  #33
rickduff's Avatar
rickduff
St. Jude Donor '14
Oh man, you made me laugh out loud at that line. (of course I manage firmware engineers so I laugh at weird things)
Old Jan 29, 2014 | 04:48 PM
  #34
pgway's Avatar
pgway
Then you would know there is no rheostat in the C7 Corvette!
Holding?
Old Jan 29, 2014 | 05:16 PM
  #35
JoesC5's Avatar
JoesC5
Maybe to keep the accelerator from flopping around like a fish out of water, GM installed an old fashioned torsion spring on the pedal's pivot rod.
