V4 Mode
Old Jan 26, 2014 | 11:34 PM
jimsragtop's Avatar
jimsragtop
Default V4 Mode
I have driven my car in all modes and I understand there should be a light that comes on in the center cluster when the car is in V4 mode. With over 1500 miles on the car , not once have I seen this light, is this correct. I have read on here where you cannot hardly tell when the car switches from V4 to V8. I think the car goes to V4 but I am not 100% postive. If it is just a lamp unpluged I don't know if I want the dealer cracking my dash open just to plug it up. Any thoughts??
Old Jan 26, 2014 | 11:44 PM
rsvette12's Avatar
rsvette12
You have to be in a certain screen, I know today I was in sport mode with a sub screen that showed how many miles left till needing more gas in that screen you will see a small v4 or v8 readout, its there just look for it, your car is fine you just need to find that screen.
Old Jan 26, 2014 | 11:45 PM
Glen e's Avatar
Glen e
ragtop:
stick or automatic?
unless you are in eco, you'll never see it with a stick....
Old Jan 26, 2014 | 11:48 PM
rsvette12's Avatar
rsvette12
I am explaining an automatic fyi
Old Jan 26, 2014 | 11:56 PM
jimsragtop's Avatar
jimsragtop
Yep I have an auto. I'll play around with the screens and see what happens. I figured that would show up in any screen setting.Manual did not help me much, unless I missed it.
Old Jan 27, 2014 | 12:06 AM
Glen e's Avatar
Glen e
it's pretty much a non issue - unless oyu are watching it, you can't really tell...
Old Jan 27, 2014 | 12:09 AM
rsvette12's Avatar
rsvette12
Its there you will find it, all new to me right now so I cant tell you exactly how to get there, I just happened to ask salesman where is the sreen that showed me how many miles left and he did it, on my way home I noticed the v4 - v8 light, good luck.
Old Jan 27, 2014 | 12:13 AM
rsvette12's Avatar
rsvette12
Here you go just saw it in sticky - this will help you - this is what you are looking for ===== •Fuel Range – Indicates V4/V8 Mode
Range and AVG. MPG. are displayed on the center screen on the IP.
Set the driver mode selector to Tour or Sport.
Using the left arrow key on the steering wheel, bring up the options menu.
Use the up and down arrow to select the "I" button at the top of the list which is the information menu. Press the SEL key in the center.
Now, using the up and down arrows, scroll through the available displays under the tachometer. They will scroll through the following:
•Speedometer in a digital display format.
•Trip meter A.
•Trip meter B.
•Eco Index information.
•Oil Life Remaining (expressed in percent)
•Tire pressure sensors
•Best Fuel Economy / Average Fuel Economy
•Fuel Used / Timer
•Engine hours and Lifetime RPM
Old Jan 27, 2014 | 12:24 AM
kuikz51's Avatar
kuikz51
rsvette12 pretty much got it all. you have to be in a certain mode and you can tell especially when you have the dual exhaust on all the time, you can here it kick in and out.
Old Jan 27, 2014 | 02:05 AM
SCM_Crash's Avatar
SCM_Crash
Go to the info screen > From the first item (the big MPH), Press down 3 times.
4th item in is the V4/8 mode, your instant economy and the range left on your tank.
Old Jan 27, 2014 | 03:08 AM
thedofuss's Avatar
thedofuss
•Trip meter A.
•Trip meter B.
•Fuel Used / Timer
you need a friggin' phd in mechanical engineering or computer science (fortunately, i have both) to figure out how this beast works. most people will never understand all the feature regardless of how long they own it.
To V4 Mode
