How many would opt for a ‘ride height’ button, like in the Mercedes SL? For speed bumps or steep driveways, you can push the button and the ride height rises about ½”. Push it again, and it rises another ½” or so. A third push returns the ride height to normal. Above 30 mph (I think), it automatically returns to normal.
Seems it would save a lot of cracked/ground-up splitters, especially for those who like to lower their cars. Cost? A little extra weight…maybe complexity…but worth it?
I think it would be a great option. The best of both worlds as and when needed.
Edit: I don't think I would personally choose it, however, if it came with a major weight penalty. That compromise wouldn't be worth it to me in that case.
I like the idea. Seems like it would be an easy addition to the Magnetic Ride Control equipped cars.
Why would it be easy? Magnetic ride control is nothing more than computer controlled adjustable shock absorbers. Instead of adjusting the valving it adjusts the viscosity of the special shock oil, which is reactive to an applied magnetic field.
Many high-end sports cars have similar drive-way aids - Lambo's call it Nose Lift Control, or something similar. Would be nice in the 'Vette. I think it pulls hydraulic pressure from the steering pump.
If you left the car design up to most CFers you'd end up with a 4000lb car with every bell and whistle in existence. These cars don't need a complex ride height adjustment system. They come at a certain OEM ride height for a reason. The plastic air dams are designed to scrape and taking most stuff at an angle solves that anyway.
Just sold an 07 SL55, fantastic car, only time I ever used it was when I washed the car, gave a little more room to clean inside the wheel wells. It was a very expensive piece to repair if it broke.
