Is the Valentine V1 still the top radar detector?
#61
Respectfully your both still wrong and here's why. Once the 9500ix locks on a false and is blocking it. It will not ignore Police radar
is the same area. Because it COUNTS it as another signal.
It is locked on the false and blocking it shows on the display. Any other signal same frequency comes on it COUNTS AS two and it goe's off! You people need to call Escort and talk to them.
Cheers.
#62
Sorry, can't let this slide.
1) You mean the Escort 9500ci, not the 9500i.
2) Just because it is a remote mount does not make it better.
3) The 9500ci is an STi-R+ with laser "shifters" (the new LI based ones). But the STi-R+ is better as a detector since the 9500ci does not allow the user to define band segments or turn RDR off.
4) You can add "shifters", in this case the Laser Interceptor, to any installation no matter which detector you have. You can use them even if you don't have a detector. (But then you wouldn't have any countermeasure against radar.) Even better, you can consider other laser "shifters", including the LI rival, the AntiLaser Priority.
Cheers.
Cheers.
Plus I have laser protection and radar with GPS and escort live!
You can use the V-1 I will stay with Escort
When you lose your battles you start changing subjects!
escort > V-1
#63
You need to read my rebuttal to this above. The radius for lockouts is 1/2 mile. An LEO radar with frequency close to the one locked out and far enough away that the locked out source can't be detected yet within the 1/2 mile tolerance, will in fact be ignored. This is not a theoretical problem. It has happened.
Cheers.
Cheers.
Need to call Escort because that's not how it works!
Explain it to them. Several hundred thousand miles with my Escort
and it never as happened.
#65
I didn't realize this was a battle. I am trying to educate the readers here with clear, proven, unbiased information. But it's clear you have a one track mind. In your mind anyone that doesn't agree with you is wrong, or somehow loses.
I've used many countermeasures myself and have participated in many test scenarios where many other brands and models were tested. What I've presented are not just my conclusions but represent a consensus from others who have also tested and run with detectors and jammers. There are forums specifically dedicated to countermeasures. I challenge you to search for these and to do more research. You're mind will be expanded. Unless you choose to keep it closed.
Cheers.
Cheers.
#66
Cheers.
#67
However, the Redline has no arrows and so you need to spend a little more effort trying to identify if the alert is a threat or not. This is why I say the V1 is better at increasing your situational awareness.
Another thing the RL (and STi-R+) have over the V1 is that they are not detectable by RDDs. This is important in Virginia.
Cheers.
#68
When a cop drives by with front and forward radar mounts, it show two signals for K or KA band.
#69
Cheers.
Cheers.
Radar Roy is a good site to look at he has tested them all saving me
the trouble.
I just stand that Escort company is bigger better been around longer
and sells many many more than the V-1 which still just signals
radar and laser but other than that it is old school.
Not advancing the tech nearly as much as Escort
#70
Your assertion that the V1 is "old school" is disingenuous. In terms of detection technology they are right on the bleeding edge.
Cheers.
#71
So Ersin - Based on what you know, for the average guy, which detector would you: 1) recommend
and
2) recommend if it could be purchased for $279 (the V1 trade in upgrade I can buy)?
and thanks for all the posts - they are very professional and helpful!
and
#72
You not only need to spend the money, you need to invest in learning how to set up and use the detector to maximize its effectiveness. At its base, it is a tool used to increase your situational awareness. It is not a cop finder. It is not a license to speed. It is a tool that will help you tailor your driving to the conditions, and as such is only one factor in your decision making.
There is no one best detector. If you drive mostly in the city (what a dirty shame for the Corvette owner) you may want to consider something like the Escort max. You don't need the range. But be aware of its limitations. I will assume though that Corvette owners want to take their car on the highway, at least once in a while.
If you like a clean cabin, the STi-R+ is the one for you. It will cost more and if you don't want to install it yourself (which I can understand) then plan on spending even more for a pro to install it. The other downside is that you need to keep the outside head clean or performance will suffer. This shouldn't be a problem for those Corvette owners who are **** about keeping their car looking good.
If you drive in a place where detectors are banned, like Virginia then your choices are the Escort Redline or the Beltronics STi-R+. They are immune to being detected by the Spectre Elite radar detector detector.
If you have a V1, keep it. Or upgrade it, which is my suggestion to you. There is too little difference to spend the money to switch. Conversely, if you have a Redline, keep it. Same for the STi-R+.
If you don't already have one of these and you decide on a windshield mount then it's a tossup between the V1 and RL.
The RL has more range, especially off axis, than anything else. It has spec mode but the V1 with options will show you the same information and more. You can buy the Escort Live cord and subscribe to Escort Live. I think a better solution though is to use the Waze app. I don't like to see what others have detected as I don't know how they have set up their detectors. But Live will give you lockouts.
The V1 has the arrows to show you the general direction of the detected signal. It also has a more clever way of alerting you -- you can easily change the "muted" alert volume to suit conditions. With options, viz. the V1 Connection and YaV1 app, you tailor the conditions for when an alert should be full volume, muted volume or no audio at all, whichever way you want. You can tailor the lockout settings, e.g. set the radius and direction as well as frequency deviation. You can mute under a certain speed. You can change colors. And more. YaV1 is free from the Google Android store (or whatever its called). The V1 Connection option is $50 (okay, it's really $49) but is worth it IMHO.
There you have it.
Cheers.
#73
I'm selling my trusty escort 8500 for a max. Can the V1 differentiate between active cruise on cars vs actual speed gun? If it can't then yes it is obsolete due to the false alarms.
Escort Max + blinder laser shifter = yes.
#74
#75
What (if anything) can be done about the Audis and other cars that are polluting the radar bands with their collision avoidance systems? Is that a frequency that can be tuned out (safely?) by any of the leading detectors?
My current Audi plan is to drive in and out of their rear corners in hopes that it irritates them as much as their radar is irritating me
I have to admit that I haven't even tried the BT gizmo or the Android app for the V1 yet. It's on the to-do list, but not very high I'm afraid.
Cheers,
Rusty
Cheers,
Rusty
#76
Any opinion on built-in vs. dashboard? I don't care about the concealment point, but isn't there a benefit to having the sensor higher above ground, to improve range, that favors a window mount?
#77
Here in Ellis County Texas the local sherrifs use K band just an FYI
#78
Cheers.
#79
Received 2,496 Likes
St. Jude Donor '15
"In honor of jpee"
I can't speak to the questions above, but just a humorous note: while you would spend "only" $279 for an update, the fact is you have maybe $400+ the $279 in it, or will. So, if there's a "real" dollar number you should be targeting, it might be more like $680 vs. $279.
Why do I say that? Because I have a sense of humor about my detector which, due to shipping, updates, replacement update, etc. is (as I call it) the world's most expensive single radar detector: I am way over $700.
And one last thing: ersin is correct in his statement "At its base, it is a tool used to increase your situational awareness. It is not a cop finder. It is not a license to speed. It is a tool that will help you tailor your driving to the conditions, and as such is only one factor in your decision making. "
For those who believe you can "beat a LEO" every time at 20 or 30 or more over the limit using the best radar detector, I say you are wrong. More than several years ago, the best instant-on at the time, used by very skilled people in the right location was unbelievably good----for LEOs. Radar has not gotten worse over the years.
#80
Agree....Ersin, you did a great job that I really appreciate! I learned a lot from your knowledge!
ersin - Wanted to say thank you. Your posts were very educational and you kept your cool, even with some flame-bait replies.
