Another clear bra question....
Old Feb 3, 2014 | 02:58 PM
Txa99ie's Avatar
Txa99ie
Default Another clear bra question....
Can't find a thread with this.....Obviously you want the car clean before applying a clear bra. But should you clay it, polish it, seal etc. before the bra goes on? What's the correct order of operations? Seems you would want it before but I hear it may cause adhesion issues. Thanks in advance for the expertise.
Old Feb 3, 2014 | 03:12 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Wouldn't be a bad idea to clay it. Polish only if there are imperfections that would show through.
Not sure about sealing but "waxing" is a definite no as they'll strip it off before applying the bra (if they know what they're doing that is)
Old Feb 3, 2014 | 03:46 PM
jokerdev's Avatar
jokerdev
^ +1
Yes, you want to clay it to remove contaminants. You could use a light polish just to remove any swirls/scratches from dealer detail. After you're finished, you want to strip all polish/waxes off so that the clear bra adheres to the clean surface properly.
To Another clear bra question....
