Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- C5 C6 Corvette: How to Disable Skip Shift (CAGS)
Step by step instructions for do-it-yourselfers...
C7 Corvette Stingray Skip Shift Eliminator - CAGS - 1 to 4 eliminator!
#41
I received my kit this week and got my new Z51 in yesterday. Installing the CAGS today I encountered a problem. The CAGS defeat plug snaps into the transmission just fine. However the black protective cover for the factory wiring harness does not snap onto the harness. Inside the protective cover there is a black "tooth" right between the two metal pins. Without modifying it there is no way it will snap onto the factory plug. Anyone else have this issue?
Hopefully we get information as to whether it is just a few defective items with this flaw or if there is an issue with the connector. I haven't installed mine yet and don't really want to go through the process until I know if it is an issue. I have a small black tooth too but it is really small and I don't know that it would interfere... Southern Car Parts, any comments?
#42
I too had this issue. I lifted my Stingray yesterday and easily found the connector on the tranny. The provided plug easily snapped onto the tranny. However, the tooth inside the CAGS sensor does not fit the wire harness. I ended up trimming away the portion of the tooth that attached to the side of the sensor. This centered the tooth and allowed me to snap the sensor onto the harness. I zip tied it up and went for a test drive. It worked perfectly, no more shift skipping. It is curious that SCPs is shipping these sensors that do not technically fit our cars.
#44
#45
Proctoman good to hear
#46
I did the same thing. I used a dremel on the piece of the tooth that attached to the wall. Made it match the plug. For people willing to spend a little time modifying this won't be that big of an issue. But there must have been a plug change because I can promise you it will not go in without trimming that tooth. I haven't got a chance to test mine out since its raining today.
#47
Good for you. Pretty easy fix. I actually used an exacto knife to trim the tooth. Even though I have eliminated the skip shift, I still get the dash message that says it is skip shifting. When you get a chance to test yours out let me know if you are still getting the dash message also.
#48
My friend has had is C7 for 4 months with over 2000 miles of almost all city driving and never had the 1-4 shift problem arise at all except for two times when he was doing his best to cause the problem. drove over 30 minutes around town trying to force it one day and it never did do it so he isn't buying a kit for his. I have a C7 coming and already have bought the eliminator but probably won't install mine either since it is a virtual non issue.
ps When it does show it will almost invariably be at a bad time for it to happen.
#51
Someone else mentioned this same problem and had to remove the piece blocking the connection.
#52
#53
E-Ray, 3LZ, ZER, LIFT
Received 9,625 Likes
#54
Location: I live my life by 2 rules. 1) Never share everything you know. 2)
Received 2,402 Likes
St. Jude Donor '11-'12-'13, '16-'17-'18
800+ miles on my C7 and I have YET to see CAGS enforced. Not once.
Thinking about selling my never installed CAGS eliminator.....
#55
It won’t come on unless you’re trying to shift below 15 to 18 mph. Doesn’t happen often but I found it happens at the worst time! If you’re in stop and go traffic and want to shift out of first, when you go to shift and not expecting it won’t go into 2nd, the car slows. The person behind you, (who may have decided it was a good time to answer a text) expects your car to be moving forward - not slowing! It is very annoying and frankly I don’t look for lights telling me I must shift to 4th! Well worth the small cost and is an easy install.
#56
Mine doesn't have it either.
BTW - At least the Black piece is circumcised. One less thing to deal with when trying to install it.
#57
Moderator
If you have had a post deleted in this thread it is because you have violated one or more of the following rules:
Interference in a For Sale thread (yes, this is a for sale thread - they don't have to be in the for sale sections to qualify - read the sticky Vendor threads in C7 General)
Online Conflicts
Personal attacks/hostility towards others
Online Conflicts
#58
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
Hey guys, we had a few c6 ship instead of c7....so if you got one that didn't snap into place WE WILL REPLACE FOR FREE, just shoot us an email or call. This will not happen again. We've got the in stock and ready to ship.
#59
Thanks for the quick response. They had my issue taken care of first thing this morning.
