Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-Tos
- C5 C6 Corvette: How to Disable Skip Shift (CAGS)
Step by step instructions for do-it-yourselfers...
C7 Corvette Stingray Skip Shift Eliminator - CAGS - 1 to 4 eliminator!
#62
#65
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
#66
Does the CAGS actually block the shifter from going to 2nd gear, so when you try to put in 2nd gear the "gate" is blocked and you have to move the shifter horizontally to the right and then down to find 4th gear? Or does the CAGS actually work so the shifter goes "diagonally" down to 4th gear?
#67
Does the CAGS actually prevent the shifter from going to 2nd gear, so when you try to put in 2nd gear the "gate" is blocked and you have to move the shifter horizontally to the right and then down to find 4th gear? Or does the CAGS actually work so the shifter goes "diagonally" down to 4th gear?
#68
Our C7 skip shift eliminator kit comes with everything you need to install without modifications. We did have some issues with the incorrect skip shift being sent for the C7's but that issue has been fixed.
Once you are under the car installation is simple. Here is a video on the install process.
C7 Corvette CAGS Skip Shift Eliminator Installation Video.
A couple of us have asked this and we have no response, perhaps you missed the posting.
Please respond.
#69
Supporting Vendor
For those of us who recently ordered can you please tell us (Show us) what the correct part is supposed to look like so we don't waste time going under the car with the wrong (C6 instead of C7) part??
Please respond.
Please respond.
We sent our 4 C6 units, last one shipped 2 weeks ago. So if you ordered in past 2 weeks you have nothing to worry about.
Thank you
#70
So, other than the cap not fitting correctly (which I modified to make fit) is the internal resistor / functionality still correct?
#71
That sounds incredibly dangerous and something that is likely to cause accidents especially if you have no idea when it will happen, that's like intermittent sudden de-celeration when you can't get it into gear and have to coast when people are expecting you to accelerate. Sounds like an accident waiting to happen in stop and go traffic. Can dealers or independent Corvette shops install the eliminator?
#72
#73
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
#76
I find that if you carry your rpm above 3000 - 3500 rpm before shifting to second there is never an issue. There is actually a message that comes up on the HUD that flashes off as soon as a certain RPM is exceeded.
#77
It’s not normally an issue but that is part of the problem since you are not expecting it to happen! When in stop and go traffic, shifting out of 1st below 15 to 18 mph will cause it to block shifting to 2nd or 3rd. When not expecting it to happen, I have fumbled and the car slows. In todays world with some folks texting while driving, that could mean the person behind you, who is distracted and wasn’t expecting you to suddenly slow down, hits your rear!
#79
same here with me and every one I have talked to with C7. Seemed to be an almost mandatory thing to buy with the C6 and other GM cars with the 6 speed but the C7 must be programmed with such a small window of forcing the 1-4 shift that it is not a problem. Lady at car show last week said she seen it on dash light that the 1-4 shift would be on but she shifted fine into second even with the light on dash.
#80
To each his own, but that is my opinion.
