seats won't program
Old Feb 28, 2014 | 06:37 AM
kevingilmore's Avatar
kevingilmore
Default seats won't program
car on (or off) and in park
move seat to new position
push set and position 1 and no beep
new position not saved.
used to work??
Old Feb 28, 2014 | 05:34 PM
kevingilmore
turns out you have to hit both buttons at pretty much the same
exact time. which I can't do with my left hand with the door closed.
Old Feb 28, 2014 | 05:51 PM
F4 Phantom's Avatar
F4 Phantom
Just keep trying with the engine on in park and work as fast as you can.
Old Feb 28, 2014 | 05:53 PM
Modshack's Avatar
Modshack
Don't you have more than one hand?......
Old Feb 28, 2014 | 05:55 PM
Zymurgy's Avatar
Zymurgy
Moderator
Storing Memory Positions
To save positions to the “1” and “2”
buttons:
1. Adjust the driver seat, outside
mirrors, and the power tilt and
telescoping steering column to
the desired driving positions.
2. Press and hold SET and “1” at
the same time until a beep
sounds.
3. Repeat Steps 1 and 2 for a
second driver using “2.
The buttons are up well above the arm rest on the door. Should be in reach of your left hand. If that is awkward, reach over with your right hand.
Old Feb 28, 2014 | 08:07 PM
kevingilmore
torn rotator cuff...
Old Mar 1, 2014 | 02:17 AM
orlanderlv's Avatar
orlanderlv
Something that happened to me is the buttons and button housing came loose and broke. I had to take my Ray down to have it fixed. Please check to make sure the buttons are securely housed else the wole button group might not work.
To seats won't program
