Removing side reflectors
Old Mar 3, 2014 | 07:17 PM
BADA BING's Avatar
BADA BING
Default Removing side reflectors
anybody have the best way or instructions on how to remove the amber and red side markers so i dont break them?
thx
Old Mar 3, 2014 | 07:25 PM
LuvnMyC7's Avatar
LuvnMyC7
thx
Pull out the fender wells to access them or remove the bumper covers to take them off from inside. They come out from the inside, not the outside
Old Mar 3, 2014 | 07:41 PM
BADA BING's Avatar
BADA BING
thanks for the advice.. Do the fender wells just pop off by pulling them?
Old Mar 3, 2014 | 08:08 PM
slief's Avatar
slief
Fender liners are held in place by a bunch of screws. Remove the wheel and you will see them in the wheel well. There are also a couple screws underneath just in front and behind the wheels. You will also need to remove the splash guards. You really only need to remove half the screws and just pull the fender liner back enough nearest the reflectors so you can access the screws holding the reflectors in place.
Old Mar 3, 2014 | 08:18 PM
2 Ag R8Cs's Avatar
2 Ag R8Cs
From: Retired Suffolk County Police Dept NY South Carolina
It will probably cost a few bucks to get the holes filled and repainted. As long as you are going to pay a body shop to fill and pain the holes why not let them do the removal.
I don't care about the reflectors but I do hate the Daytime running lights, I would like to get them permanently disabled
Old Mar 3, 2014 | 08:19 PM
BADA BING's Avatar
BADA BING
I didnt realize I needed to take the wheel off, I guess I cant access the fender liner screws without taking the wheel off?
I was looking to replace them with smoked lenses not remove them completely --2 Ag
Old Mar 3, 2014 | 08:30 PM
Larry/car's Avatar
Larry/car
I don't think that's legal in PA. Might be a problem at inspection.
Old Mar 3, 2014 | 08:37 PM
CCDawg69's Avatar
CCDawg69
Don't like the Daytime Running Lights!!! I guess to each his own but I find them unique to the Stingray and complements the car.
Besides, if you're in the drivers seat you can't see them!!
Old Mar 3, 2014 | 08:43 PM
edloke's Avatar
edloke
Suggest you not remove. Carefully mask and spray with the darkening spray at parts store. Works fine
Old Mar 3, 2014 | 08:56 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I didn't like 'em in the C6 because they were incandescent, generated a LOT of heat and eventually burned their sockets. As such, I used to turn 'em off all the time.
No such concern with the C7's and I do think they look
Old Mar 3, 2014 | 11:13 PM
LuvnMyC7's Avatar
LuvnMyC7
You probably already known this, but if you flip the light switch back to the off position, the daytime running lights will turn off. Just have to do it every time you get into the car.
Old Mar 4, 2014 | 12:11 AM
2 Ag R8Cs's Avatar
2 Ag R8Cs
I am in the habit of doing it, I did it every time I started my 2012 Volt and every time I start my 2014 Silverado. I would just like to have it fixed so I do not have to do it every time I start up
Old Mar 4, 2014 | 12:20 AM
thedofuss's Avatar
thedofuss
thx
you may not be able to pass your state inspection if you remove them. certain safety provisions that are stock can not be removed. of course, your inspection station, if not a corvette dealer would likely not know this, but its your risk if you do not check your law. "a word to the wise should be sufficient". thedofuss, ca. 2014.
Old Mar 4, 2014 | 01:31 AM
m3incorp's Avatar
m3incorp
Default Tint the lenses
There are venders that sell tint that you apply to the outside of the lenses. I think that's how they are on Glen e car.
Old Mar 4, 2014 | 10:01 AM
BADA BING's Avatar
BADA BING
was looking at a more professional look then just the tint, I see a vendor has led lights that run all the way down the reflector but want to ensure I remove them properly as everything these days are crappy tabs that break off if you dont know what you are doing.
Old Mar 4, 2014 | 09:23 PM
Should look pretty good. Post up pics when you get it done.
To Removing side reflectors
