Looking for under the dash power
Old Mar 22, 2014 | 09:18 PM
luvlake's Avatar
luvlake
Default Looking for under the dash power
There has to be somewhere under the dash, fairly easy to access, a power source. I want hard wire a Valentine Radar Detector, and didn't want to disassemble the console to get power there or use the computer access for the SAAVY.
Old Mar 22, 2014 | 10:05 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Access to the center console is ultra easy. It literally can be done in under 2 minutes
Old Mar 22, 2014 | 10:39 PM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Or that famous fuse #37 under the rear carpet...
Old Mar 23, 2014 | 01:16 AM
george vee's Avatar
george vee
2015 C7 of the Year Finalist
This video will show how easy it is to take console apart..
http://forums.corvetteforum.com/c7-g...nd-videos.html
Old Mar 23, 2014 | 02:00 AM
KenHorse's Avatar
KenHorse
Yup. VERY simple to remove and replace
Old Mar 23, 2014 | 02:22 AM
slief's Avatar
slief
I Agree with the others. Pulling the console up is simple. A 10 minute job or less for the inexperienced who read up on what to do. I could actually do it in 5 minutes or less and there is no reason to even remove it completely. You just need to lift it up over the gear shift **** to access the wires with the shifter in place.
Old Mar 23, 2014 | 03:21 AM
luvlake's Avatar
luvlake
Ok, thanks!
Old Mar 23, 2014 | 10:23 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
OK, I've looked at that damn film multiple times. My take on it is this:
1) Remove Console Door
2) Remove driver-side trim piece.
3) Remove small triangle piece of trim driver side (this might not be needed)
4) Place gear shift in 4th or D and pry up console to access wires
5) Make connection to cigarette lighter lead.
Reverse 4 - 1 and done.
Is that a fair assessment or did I miss something?
Elmer
Old Mar 23, 2014 | 11:24 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Have my car since early October. Many of us have used fuse #37 that is for the console plug. Lots of posts on the issue. I had tried unsuccessfully to wire into the vanity mirror light since I was concerned about going “all the way to the back fuse panel,” however it is very easy. It is located at the rear of the panel so you don’t have to even uncover the whole fuse panel to attach an Add-A-Circuit. It is also very easy to tuck wires under the molding along the floor and up and under the rear carpet without any tools. If you route the wires on the passenger side the only difficulty is lifting the carpet to get at the battery, probably need to learn to do that anyway, in case it’s ever needed! Have step by step details on my web site with pics: netwelding.com/reports_vette_info.htm Note I also routed the wires to the top of the windshield and they are hidden. Only one small piece of molding in the door jamb was removed to hide the wires. You certainly can get the 12 volts however you wish, just my suggestion!
Old Mar 23, 2014 | 11:55 AM
LIE2ME's Avatar
LIE2ME
I wonder if it is any different if I choose to run the wires down the driver's side instead of the passenger side...
Old Mar 23, 2014 | 11:57 AM
KenHorse's Avatar
KenHorse
Elmer
You're correct in that you don't need to do #3 and right on about the rest.
Old Mar 23, 2014 | 02:03 PM
eboggs_jkvl
Moderator emeritus
Gracias Amigo! I'm good to go on this task when I get my car.
Now, if blendmount will just get their $hit together and come up with a mount for the C7, the world will be my oyster!
Elmer
Old Mar 23, 2014 | 02:15 PM
KenHorse's Avatar
KenHorse
Elmer
I'm currently working on one with a machinist buddy of mine. It will mount under one of the visor clip mounts
Old Mar 23, 2014 | 08:48 PM
C6Corvet's Avatar
C6Corvet
Just get the Invisi cord and plug it into the back of the mirror I have done it on my both vets & my truck works like a champ.
Old Mar 23, 2014 | 08:49 PM
KenHorse's Avatar
KenHorse
Doesn't work on the C7 as there's no connector on the back of it
Old Mar 23, 2014 | 09:38 PM
LIE2ME's Avatar
LIE2ME
Originally Posted by slief
I Agree with the others. Pulling the console up is simple. A 10 minute job or less for the inexperienced who read up on what to do. ...You just need to lift it up over the gear shift **** to access the wires with the shifter in place.
Once the wires are accessed, what's the best way to tap into them? Is there a plug of some kind that would fit between the power plug and the preexisting wire? I am looking for the safest, surest, most idiot proof approach...
Old Mar 23, 2014 | 09:39 PM
fdxpilot's Avatar
fdxpilot
Spoken like a true C7 non-owner. I had invisicords on my C5 and both C6s, but it won't work on a C7 mirror.
To Looking for under the dash power
Old Mar 23, 2014 | 09:44 PM
KenHorse's Avatar
KenHorse
I've never been a fan of wire taps (like those car stereo shops use) so I stripped back the wire before it enters the connector body (to the cig lighter socket), solder and tape it. I also stagger the plus and minus lines so there is no possible way for a short to occur should the tape ever come off - that is to say I strip the + line back 1/2" from the connector body and the - line 1" back. Like I said, no way to short together that way.
I also placed a 1 amp inline fuse with the + lead leading to the radar detector, close to the tap point. Not so much to protect the detector but rather the wiring to it.
Old Mar 23, 2014 | 09:57 PM
eboggs_jkvl
Moderator emeritus
No connector and no 12v. Ain't gonna work on the mirror.
Elmer
Old Mar 23, 2014 | 10:41 PM
mike1952's Avatar
mike1952
St. Jude Donor '04-'05-'06-'07-'11-'12-'13
Default Mirror mount
Great Lakes Trophy has a Valentine and Escort mount. Better than Blendmount in my opinion.
