C7 Lowered
Old Apr 18, 2014 | 02:43 PM
rsvette12's Avatar
rsvette12
Default C7 Lowered
Ok dealer lowered looks way better - actually amazing difference
Front lowered from 27 3/4 to 26 5/8
Rear lowered from 27 3/4 to 26 3/4
Now I am noticing a slight pull to the right, so I would advice you might want to have your alignment checked, dealer did not have a drive on machine so I have an appointment with a local guy I use for my daily driver and He has the correct setup.
Moral of the story is lowering probably will result in 4 wheel alignment
Pictures to follow after the rain crap cold weather leaves
Oh by the way wow the C7 is one incredible car and the attention it gets is like nothing I have ever seen.
Thanks so much Jeremy for the sticky - brought that to the dealership - priceless Buddy
Old Apr 18, 2014 | 02:54 PM
E.T.D. Corvettes's Avatar
E.T.D. Corvettes
C7 & C8 Events Correspondent
2020 C8 of the Year Finalist - Unmodified
2020 Corvette of the Year (track prepared)
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Thanks for the post! And post some pics!
Old Apr 18, 2014 | 03:00 PM
rsvette12's Avatar
rsvette12
Will do Buddy - have some mods done also
Old Apr 18, 2014 | 03:12 PM
E.T.D. Corvettes
2015 C7 of the Year
Looking forward to seeing what you've done!
Old Apr 18, 2014 | 04:39 PM
GreG L.'s Avatar
GreG L.
So I've read about lowering and seen pictures of C7's lowered, my question would be is it a problem with GM in any way if I have it done and is there a downside other than speed bump management?
Old Apr 18, 2014 | 04:47 PM
slief's Avatar
slief
Pulling.. That is interesting. I had no pulling when I lowered my car. Did you measure both sides yourself to see if it's even? To me it sounds like ones side is lower than the other if it's pulling.
Old Apr 18, 2014 | 05:04 PM
E.T.D. Corvettes
2015 C7 of the Year
No problem with GM with lowering on factory bolts. And the only potential downside, other than speed bump management, would be the possible need to have your alignment adjusted.
Old Apr 18, 2014 | 05:09 PM
rsvette12's Avatar
rsvette12
Hi Scott - Had the best corvette Chevrolet dealership around my area, they have always done top notch work on all of my vettes, known this service manager as a straight shooter so if He measured all sides I believe Him, its not earth shattering just a slight pull to the right but I am taking it tomorrow to be sure.
Old Apr 18, 2014 | 08:31 PM
stevebz06's Avatar
stevebz06
I have responded to several posts about lowering and the need for alignment and I don't remember anybody responding to me. Whether this is the result of my being "ignored" or nobody believes me, I don't know, but, for one more time, I have done a number of alignments on C5's and C6's, and the rear will go TOE OUT with full lowering in the rear. Not less toe in, but toe out.
Given that the C7 is so similar to those other cars, I would strongly suggest planning an alignment along with lowering. Not when you can get around to it.
If alignment is impossible, for some reason, limit your driving until it can be done, and do not drive the car hard, especially with the handling modes turned off, because if the rear toe does what I think it does, the car will be very unstable.
Old Apr 18, 2014 | 08:34 PM
Glen e's Avatar
Glen e
Mine was lowered all the way and checked, close enuf to spec for a DD....4500 miles and excellent wear and operational behavior.no alignment for me.
Old Apr 18, 2014 | 08:45 PM
stevebz06's Avatar
stevebz06
Well, maybe they changed the geometry on the 7 enough to make a difference, although with my first Vette, my car was almost undriveable when I first took it home and still was after the dealer performed an alignment in response to my complaints. Only after I took the car to a reputable performance car shop and paid over $200 in 1987 did I find out what a good handling car it was. This is one reason I decided to learn how to do it myself.
Old Apr 18, 2014 | 08:47 PM
Steve Garrett's Avatar
Steve Garrett
CORVETTE TODAY Show Host
CORVETTE TODAY Host
St. Jude Donor'15
My dealership lowered my C7 on the factory bolts. They also did an alignment.
Old Apr 18, 2014 | 09:20 PM
rsvette12's Avatar
rsvette12
"I have responded to several posts about lowering and the need for alignment and I don't remember anybody responding to me"
Sorry Steve I did not catch your post but I believe you are right, after taking it down the street I said wait something is wrong here and headed back to dealership after a mile down the street
Old Apr 18, 2014 | 09:24 PM
Steve Garrett
CORVETTE TODAY Host
St. Jude Donor'15
No worries-I hope everything works out well!
Old Apr 19, 2014 | 10:32 AM
rsvette12's Avatar
rsvette12
Well had 4 wheel alignment, rear was a bit off and the front was quite a bit off, actually watched Him do it, I would suggest you have this done for sure if you lower your car, as for lowering way better after seeing pictures unlowered C7's
Old Apr 19, 2014 | 10:43 AM
E.T.D. Corvettes
2015 C7 of the Year
Yes, it's a good thing to have the alignment checked after making a suspension adjustment. No doubt about that.
Here's another thought...some cars will come out of the factory out of alignment. That's why a first time alignment is a warrantied repair. It's a good idea to have your alignment checked anyway, whether or not you lower your car.
Old Apr 19, 2014 | 11:20 AM
stevebz06's Avatar
stevebz06
This is good advice. By my experience, a significant number of cars delivered by GM have alignment problems. Not just Corvettes, either. The only problem I see is that getting an alignment performed doesn't guarantee that it will be a good one. In principal, it's a pretty easy thing to do, but for some reason a lot of shops can't seem to do consistent work.
If you can find somebody who is good, and I'm talking about the individual mechanic, not the shop, I would take care of that guy and even exchange phone numbers or emails so you can follow him if he changes jobs.
To C7 Lowered
Old Apr 19, 2014 | 02:07 PM
Dave1's Avatar
Dave1
St. Jude Donor '09
Is the visual benefit in lowering the car that much worth losing some of the driving characteristics….?
If it's a garage queen I can see why but, for folks who like to drive I'm not so sure...
Old Apr 19, 2014 | 02:16 PM
rsvette12's Avatar
rsvette12
No garage queen here - I like driving them not looking at them - lowered and handles like a dream.
Old Apr 19, 2014 | 02:18 PM
Steve Garrett
CORVETTE TODAY Host
St. Jude Donor'15
^^^ Me too, Rich. I didn't buy it to let it sit.
