At start-up-idle, the oil pressure is 40 pounds and after the engine is hot the idle pressure crops to 30-35lbs.
This seems rather low to me. I know this is a different engine from the past, but still a small block 327; and all of the previous Vets I have owned and driven; the oil pressure was always higher than these readings.
Maybe this normal for this engine; what is your opinion?
mine is at 35 most of the time. I am old and old school and like to see 60+ pounds and less than 180 degrees on water temp but I guess these new engines running at 220 degrees with thin oil and low oil pressure are the thing now.
Couple things at play. GM moved the oil pressure sender from the rear of the engine to the front to make sure the sensor is seeing the oil pressure after the last main bearing. According to GM that drops the reading 7-10psi from the LS engines.
Second the oil pumps are variable displacement with a pressure control valve thats controlled by the ECM, high oil pressure = horsepower so at low RPM/load the pressure is kept lower than high rpm/load.
Compared to C5 and C6 Corvettes the oil pressure appears low, but normal.
