Differential change
Old Apr 29, 2014 | 07:16 PM
v8capt's Avatar
v8capt
Default Differential change
Is it necessary to change the differential fluid on the stingray. If this is been asked before I could not find it in a search.
Old Apr 29, 2014 | 07:24 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I couldn't find anything in the owner's manual but this.
Rear Axle
When to Check Lubricant
It is not necessary to regularly check rear axle fluid unless a leak is suspected or an unusual noise is heard. A fluid loss could indicate a problem. Have it inspected and repaired.
I'd say 100,000 is a fair guess to check the fluid level and maybe change it?
Elmer
Old Apr 29, 2014 | 07:49 PM
leadville1's Avatar
leadville1
I would change the fluid for sure, it is not a bad idea to change the fluid shortly after break in for the diff and the tranny (manual). I plan on changing all my fluids after 500 miles.
If your tracking the car you should change it after every season or sooner. Fluids are much cheaper than the alternative.
Old Apr 29, 2014 | 07:55 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Unless you track it hard there's no reason to change the diff oil until at least 50k miles. Doing it at 500 miles can't hurt anything but is a total waste of money.
Old Apr 29, 2014 | 08:14 PM
NSC5's Avatar
NSC5
I change out the differential fluid by at least the first 1,000 miles in every vehicle I own. There is usually quite a bit of wear that occurs during break-in which means material ends up in the fluid. However the only place I have seen the early change required by GM is for the rear differential of the HD pickups which do require (at least for my 2001 and 2006) the fluid to be drained and replaced after initial break-in mileage and again after the first heavy towing.
It is probably OK to leave in but I prefer to get the particles that result from early break-in operation out of there.
Old Apr 29, 2014 | 09:11 PM
xp800's Avatar
xp800
Thinking of doing this too. Any idea if the change procedure is complicated by the Z51 coolers? I seem to recall this may have been the problem with the early Z51 low ediff fluid.
Old Apr 29, 2014 | 09:24 PM
simplegto's Avatar
simplegto
St. Jude Donor '11-'12-'13-'14
look at the old oil in the sun and you will be glad you changed it.
Old Apr 30, 2014 | 07:41 AM
leadville1's Avatar
leadville1
That is an ignorant answer, have you ever seen what comes out of new Dif after break in?
Old Apr 30, 2014 | 10:08 AM
Steve_R's Avatar
Steve_R
Yup. Particularly since I've built a lot of different differentials and installed a lot of gears. Just because you think you can see something doesn't mean there's a problem with the oil. If that were the case GM and all other manufacturers would recommend diff oil changes after break in, which none do.
Careful with your "ignorant" comments, unless you want to have a detailed discussion about differential gear install, setup, break in, etc. You'll lose.
Old Apr 30, 2014 | 10:17 AM
eboggs_jkvl
Moderator emeritus
The rear end maintenance issue isn't in print ANYWHERE in the owner's manual. Check, change, replace, most everything else but they omit the differential except to say check the fluid level if it makes noise and if low, take to the dealer. I will follow their instructions.
My C6 had noisy chattering clutch plates. I changed the oil out (recommended by GM) to Amzoil, or the like, and fixed the problem. Otherwise, I would not have touched the rear. Since the oil change, I haven't done squat to the differential.
Elmer
Old Apr 30, 2014 | 10:32 AM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I have no skin in the game, but just for information I'll let you know I owned my street driven '97 C5 2:73 equipped A4 for 17 years and 62k miles, and never once changed the fluid. As far as I know nothing says there is a problem with micro sized particles present in the fluid of a lubricated device given the clearance dimensions between metal components. I might add, the differential never made a whine or sprung a leak either, unlike a lot of other C5s of that era.
Old Apr 30, 2014 | 10:54 AM
Steve_R's Avatar
Steve_R
For a little clarification, here are the key differences between an engine and a differential as far as oil contamination, clearances and oil change frequencies.
In an engine there are a lot of journal bearings with very close tolerances. There is also fuel and exhaust gases in an engine that can chemically contaminate the oil. Chemical contaminates and/or particles can destroy the soft surface of a journal bearing, thus the frequent oil change interval.
A differential has roller bearings, not journal bearings. The tolerance on roller bearings is much looser than a journal bearing, and there is no soft surface in a roller bearing, they are incredibly hard. The tolerance between the ring and pinion gear is very loose (much looser than most people would expect). There is no fuel or exhaust gas in a differential to chemically contaminate the oil.
The break in period for new gears in a differential is very short. There is no break in period for the roller bearings. That's why there is no mention of any break in procedure for differentials from any auto manufacturer. While changing the diff oil after some perceived break in period on a new car won't hurt anything, it's not needed, isn't helping anything, and is a complete waste of money and resources.
Old Apr 30, 2014 | 11:32 AM
cb98coupe's Avatar
cb98coupe
On my previous 2 C6's that I owned , I changed the rear end fluid because the first one had chatter and was replaced under warranty . The second one I bought used and had 25k miles and I did it just for the heck of it . This vehicle I am not going to do anything . Also , I used to change my oil the first 1k miles and I am also going to wait until the OLM tells me to do so . I am jumping off the way too much maintenance bus , but that's just me . Do what makes you feel good and enjoy your car .....
Old Apr 30, 2014 | 11:35 AM
Higgs Boson's Avatar
Higgs Boson
this is not a correct statement. there are manufacturers, like Mercedes benz AMG products, that require a differential service early in the cars life (1000 miles). as mentioned, chevy trucks have an early diff service. BMW M series cars require a 1200 mile diff service. there are others.....
Old Apr 30, 2014 | 11:49 AM
$$$frumnuttin'
Old Apr 30, 2014 | 11:57 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I'd love to see someone post up some pics of the replaced diff and tranny fluids.....
Old Apr 30, 2014 | 12:03 PM
Kracka's Avatar
Kracka
All the AWD Subarus and Mitsubishis call for regular rear differential (and transmission) fluid changes as well.
To Differential change
Old Apr 30, 2014 | 12:05 PM
Steve_R's Avatar
Steve_R
I've never taken pics of drained fluids.
If drained lubricants, especially engine oil, looked "clean" it would be an indication that it wasn't doing its job. The only real way to tell if a lubricant is still good is testing, not looking at it.
Old Apr 30, 2014 | 12:15 PM
KenHorse's Avatar
KenHorse
I get that. But I was directly addressing leadville1's comment:
So....let's see it and why it makes Steve_R's claim "ignorant"
Old Apr 30, 2014 | 01:14 PM
Mike Mercury's Avatar
Mike Mercury
ya' mean there's still people around who get fooled by those oil-change places where they compare new tranny/diff/power-steering fluid to a sample they just took from your vehicle?
Of course it will change color and consistancy - during the time it's working properly.
