FWIW, there is a battery jump start terminal under the hood. You have to remove a small cover over it. That should be a sufficient place for a battery check.
See Jump Starting on page 10-65 of your owners manual.
I see nothing at 10-65 in my manual about jump-start terminals under the C7's hood. Is there something in the manual indicating the location of these under-hood terminals? Thanks!
It's not in the manual, but check here (from the FAQ section)
I haven't seen this before .. that's a very cool way to do it .. I don't much like closing the hatch on a wire .. this eliminates that altogether. Good find. I'll have to see if I can adapt that to my Battery Tender ..
(edit)
Never mind .. I see it IS for battery tender. I'll be ordering one of these .
