Launch control?
Old May 10, 2014 | 10:59 PM
EVL-C8's Avatar
EVL-C8
Can someone with a non z51 auto verify that this will work and if so can you have someone video your steps in the car to share? I thought I was doing something wrong and tried again today with the same results and now see others are having the same almost stall no rev issue I have?
Old May 16, 2014 | 10:01 AM
GameY2j's Avatar
GameY2j
8th Gear
Anybody with an automatic non z51 successfully get the launch control to work?
Old May 16, 2014 | 07:31 PM
EVL-C8's Avatar
EVL-C8
Can someone please post the correct steps for a non Z51 automatic?
Here is what I have tried that does not work?
In "Track" mode:
Press the traction control button twice.
"Competitive Mode" shows on the DIC.
Put car in Drive.
Press on Brake,
Floor the Accelerator and the rpm's will not raise in fact, they drop to the point of almost dying?
I have tried this in Manual Mode 1st gear also with the same result?
Am I doing something wrong or is this NOT AVAILABLE on the base automatic?
Old May 17, 2014 | 10:02 AM
EVL-C8's Avatar
EVL-C8
Well according to the Chevy Dude it is not available on the Non Z51 car?
But the Video states "doesn't matter what model you have and even available on the automatics" Not one word about Z51's only!
The chart shows that it should also be "Available"
So what gives!
Can ANYONE from GM please verify this and/or give us the correct procedure?
Old May 21, 2014 | 08:09 PM
EVL-C8's Avatar
EVL-C8
TTT
Old May 21, 2014 | 08:27 PM
bimmerborn's Avatar
bimmerborn
FRANK121
Your procedure is correct. Yes, all Stingrays, with or without Z51, or MRC, manual or automatic have this feature. Look at the attached demo by Mr. Rick Malone and JJ (Spring Mountain Motorsports). You see even with manual tranny RPM drops at take-off. Computer's objective is to get the most traction and spin the wheels a bit over that.
Old May 22, 2014 | 12:47 AM
C5-JIM's Avatar
C5-JIM
Originally Posted by GameY2j
I have the same issue.
As I attempt the launch, the car doesn't rev up.
Instead it stays low, almost to a point where it will stall out.
I have a 3lt Automatic without the Z51 pkg.
I am in track mode and then I put it in competitive driving mode. Hold the brake down all the way and stop on the gas
Any Help Please!!!???
2LT auto-no Z51 pkg. I put it in track mode then I hold the brake down all the way and hold the accelerator to the floor. The rpms will lower to the sweet spot, release the brake pedal quickly and hold on. I have never used the competitive mode. Works for me every time. Mine will lay 8-10 ft. of rubber
C5-JIM
Old May 22, 2014 | 11:38 AM
EVL-C8's Avatar
EVL-C8
My rpms drop when I floor the accelerator while the brake is held ...... It wont rev up?
I would like to see a video of someone in an automatic doing the launch control.
Old May 22, 2014 | 11:59 AM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
C5-JIM
I have a z51 M7, but according to this post, only use the track mode.........no competitive mode.
Old May 22, 2014 | 12:56 PM
Orange05_C6's Avatar
Orange05_C6
Those videos, especially the red one, the launch control looks terrible! I could probably get off the line quicker with my c6 on my cheap tires Haha I'll never use it on my c7 when I buy one if this is how it is.
Old Jun 7, 2014 | 12:36 AM
CORVETTEZL1001's Avatar
CORVETTEZL1001
Any videos of the auto?
Old Jun 7, 2014 | 01:29 AM
Pete43's Avatar
Pete43
I have the Z-51 M7.(no mag ride) After I had my ECU flashed, my launch control works. When I press the console button twice in track mode, I see a message on the tach that says Competition Mode activated.. (or something like that) But when I floor it in first gear, it revs to around 4200 rpms, I release the clutch and I sit there spinning.. smoke pouring from the fender wells. lol Not a very fast launch.
Old Jun 7, 2014 | 02:08 AM
  #33
azula's Avatar
azula
these videos are making my wait worse....smh
Old Jun 7, 2014 | 02:56 AM
  #34
perrazi mx-15's Avatar
perrazi mx-15
we could do better launches than what I have seen so far back in the old days without all the gee-whiz electronics
