GM is also recalling 111,889 Chevrolet Corvettes from the 2005-07 model years for possible loss of low-beam headlamp operation in the wake of several hundred complaints. GM is also extending customer satisfaction coverage for 2008-13 Corvette cars, but not issuing a recall.
When the engine is warm, the underhood electrical center housing could expand, causing the headlamp low-beam relay control circuit wire to bend slightly. After the wire is repeatedly bent, it can break, which would mean the low-beam headlamps will not light. As the housing cools and contracts, the low-beam headlamp function may return. This condition does not affect the high-beam headlamps, GM said. Loss of low beam headlamps when they are required could reduce the driver’s visibility, increasing the risk of a crash. There are no reports of crashes or injuries related to the issue.
My "05 was affected. It stranded me 50 miles away from home.
I replaced it (the fu$e box) to the tune of $600. I still own the car (which I still love and drive), but so far, GM is not reimbursing the cost to those owners who did (on their own dime) what GM should have done.
