V4 eliminator?
Old May 18, 2014 | 09:39 AM
c5eddiem's Avatar
c5eddiem
Default V4 eliminator?
It would have been nice if Chevy put a software switch on the Vette so you could opt to NOT go into V4 mode. Like we can do with the NPP option. I'm sure V4 mode was done just like the CAGS setup - to keep the corporate gas mpg up.
So I'm thinking...
There's a simple CAGS eliminator to negate the 1-4 shift. It basically fakes out the system.
In the new Vette, I'm sure there is a set of variables that determine when the car goes into V4 mode. Do you think someone will come up with a way to electronically alter one of the sensors so the algorithm that makes the change to V4 is never met, and the car therefor never goes into V4 mode?
Kind of a V4 eliminator plug-in mod! Seems like GM won't do it, but the car owner certainly could, just like many do for CAGS. Just like CAGS, the mpg would suffer, but... who cares on a Vette? Especially if it's switchable.
Any thoughts?
Ed
Old May 18, 2014 | 09:54 AM
sccaracer46's Avatar
sccaracer46
So I'm thinking...
Any thoughts?
Ed
With the manual transmission, the only time it with go into V4 mode is when you select "econo-mode". I believe the cars with automatic transmissions, it is eliminated when you put it into "paddle shift" configuration.
Old May 18, 2014 | 10:00 AM
RidgebackKing's Avatar
RidgebackKing
So I'm thinking...
Any thoughts?
Ed
I think in a manual, it only does it when in ECO mode anyway.
Old May 18, 2014 | 10:04 AM
c5eddiem's Avatar
c5eddiem
I have an automatic, and wish the AFM was only active in Touring, Eco, and Weather, or separately switchable.
I've read the manual a few times. Seems like you could put the auto in M (paddle shift mode) and, except for the fact that it would start in 2nd, the auto would still shift automatically, even in M.
That's in the manual, need to see how that works out in the car next.
My research indicates a max of 12% gas savings with AFM. I'd pay the extra $$$ in gas (switchable) to get the NPP to sound consistently good by eliminating V4 activation.
Bottom line: I would prefer a V4 on/off switch. I don't see it happening as a software update from GM, but a gizmo like a CAGS eliminator or Mild2Wild switch would be a great way to implement the option.
Not sure what the specific parameters are that tell the engine it's OK to use V4. Still researching.....
Ed
Old May 18, 2014 | 10:11 AM
AFVETTE's Avatar
AFVETTE
I wonder if any of our TUNERS are working on this? I need the A6 but because of the AFM/V4 crap, so I'm rethinking getting the NPP.
Old May 18, 2014 | 10:21 AM
c5eddiem's Avatar
c5eddiem
AFVETTE,
I'm really hoping for a piece of inexpensive hardware that fakes out a sensor (like CAGS). Problem is, figuring out what sensors contribute to the AFM formula.
I don't want a tuner messing with the "brains of the operation" - no offense, tuners!
Ed
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
V4 mode is a joke, I was driving up to Kelowna on Thursday and with the cruise set, flat surface, you can feel it kicking in and out, for no reason......straight flat surface and cruise is set, why is it switching back and forth?
Old May 18, 2014 | 10:23 AM
runutzzzzz's Avatar
runutzzzzz
GM Did put a switch in. This switch has 8 positions and about $1300 cheaper LOL
Old May 18, 2014 | 10:27 AM
z51vett's Avatar
z51vett
Can you not put it in sport mode and defeat this? Maybe track mode would work new to the c7 world.
z51vett
Doug
Old May 18, 2014 | 10:28 AM
Bmbarney's Avatar
Bmbarney
I just drove on the freeway for 700 miles yesterday. I had my C7 manual in the Eco mode. I tried to drive around 65-75 all the way from Omaha to Bowling Green. I averaged 30.2 MPG. I agree that the car did go in and out of 4 and 8 cylinders. I would agree it does not seem like a race car in that mode. But isnt that the point kind-of? To have the capability of driving a race car in sport/track and then switching to good gas mode and getting 30 MPG? From my view - its thank you GM - great job.
Old May 18, 2014 | 10:30 AM
Wormwood's Avatar
Wormwood
I thought Diablo already had this in the programmer...?
If not DoD is easy to turn off with HPTuners or EFI Live.
Wormwood
Old May 18, 2014 | 10:31 AM
themonk's Avatar
themonk
I'm not saying I didn't get good fuel mileage (actually I don't know if I did or didn't, I switched it off after a while) I'm just saying that I didn't like how it kicked in and out all of the time for no apparent reason.
Old May 18, 2014 | 10:35 AM
NSC5's Avatar
NSC5
In addition to load there is an absolute timer (10 minutes max as I recall) and a cylinder heat sensor when the inactive bank becomes too cool either of which will cause it to re-enter V8 mode. This is necessary so that it can go back into V8 mode at full power at the instant required.
Old May 18, 2014 | 10:37 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Wormwood
HP does have a fix to turn of AFM. Did so in my C7 after putting headers on and having the HP tune done. Stays in the V8 mode all the time.
Old May 18, 2014 | 10:44 AM
themonk's Avatar
themonk
Old May 18, 2014 | 10:56 AM
NSC5's Avatar
NSC5
And I agree with others that it would be very nice to switch it off. I will be ordering a Z06 auto in the second year of production with museum delivery and I plan to drive it home in paddle mode to avoid V4 during break-in. Somehow track mode just doesn't sound right for break-in and I believe that is the only other way to defeat AFM when equipped with auto, it would be nice if it were an eco/tour mode only feature. But at least we don't have the annoying engine start/stop YET...
I know GM says that AFM activation isn't a problem during break-in but I would like all of the cylinders to be doing the same thing during break-in.
Old May 18, 2014 | 11:04 AM
Greg00Coupe's Avatar
Greg00Coupe
Had a custom done and part of the deal was elimination of v4. I suspect it can easily be turned off even wo a full tune
To V4 eliminator?
Old May 18, 2014 | 11:09 AM
AFVETTE's Avatar
AFVETTE
I thought I read if there is no activitiy (paddle shifting) the automatic comes out of manual mode and reenters automatic mode, meaning you'd need to perform a shift every tem minutes to trick the computer.
Or does the new A8 behave differently?
Old May 18, 2014 | 11:10 AM
NSC5's Avatar
NSC5
But a warranty friendly approach (like that for CAGS) would be very popular.
Old May 18, 2014 | 11:21 AM
kp's Avatar
kp
There is an extra position on the shifter for manual mode (pulled all the way down), it will not go back into auto mode. Its P-R-N-D-M. If you just hit the paddle in 'D' it will switch to manual mode but if you drive normal or hold the right paddle for a couple seconds it will go back into 'D' unless the shifter is in the manual position.
I've read in a few places here people saying the AFM doesnt work in track mode with an auto, thats false, only way to stop AFM is be in manual mode.
Only 'easy' way to do it trip an emission CEL, you can deal with the light and warnings but no V4 A tuner would be the easiest way, the intune supposedly doesnt leave any traces except the flash counter, not sure I would want to risk blowing the warranty for just shutting off V4 with a custom tune.
Will the Z06 for sure have AFM?
