From: Yopper of 52'yrs presently reside in WI Wisconsin
Vent Circulation/Interior
I did the search on this and didn't locate anything. So with that said is their anyway to circulate outside air through the vent system without having the AC on? Yes I can lower the windows, but looking for alternative also. if I select the vents and turn on the fan the A/C comes on. Vin #1908.
C7 of Year Winner (appearance mods) 2019
2017 C7 of Year Finalist
2015 C7 of the Year
St. Jude Donor '14-'15-'16-'17-'18-'19
Push the A/C button once you've turned the vents on and you will have just the fan. Pushing the A/C button will turn it off at that point, but will leave the fan on.
I tried this tonight and it worked as you stated, thanks for the help.
Turn it to recirculation, and the fan off. This should allow no outside air in, but with no fan it should not do anything (or close to nothing). It will still bleed heat just like the C6 does (if your temp setting is high). When your toes are burning, to turn the temp down, turn the system on long enough to engage the fan, then turn it off again. As far as I can tell, it works just like the C6 does.
