Sway bar question
I have an aftermarket sway bar set hanging around (off my C6Z) that
is slightly larger than the Z51 set that came with the car. Taking a quick peek at the front, the bars look to be of the same design but
it doesn't look like the aftermarket poly bushings will fit in that
frame area. Can someone confirm this? Looks like I need different
shaped bushings. Thank you.
