Waiting Period?
Old May 22, 2014 | 11:19 PM
Hebstar11's Avatar
Hebstar11
Default Waiting Period?
Is there a waiting period before it is safe to polish a new vehicle?
Old May 23, 2014 | 12:01 AM
Glen e's Avatar
Glen e
no..you can polish as soon as you get the car....
Old May 23, 2014 | 07:45 AM
Hebstar11's Avatar
Hebstar11
Thanks Glen e. I had heard in the past that new paint had to cure. I wasn't sure if that applied to new car finishes. I am anxious to get this Zaino process out of the way.
Old May 23, 2014 | 08:38 AM
Glenmcp's Avatar
Glenmcp
I Zainoed mine the day after I took it home.
Old May 23, 2014 | 08:50 AM
1KULC7's Avatar
1KULC7
Veteran: Coast Guard
You really should wash it in Dawn detergent, clay bar it, that put the base coats on, as soon as you get the car home. VERY tempting to just ride it around, but sooner you get that done the better. Normally I put about two coats of Z2 on, then several of Z5 spray using FRESH micro cloths. Do the wheels too. Results are worth it.
One other thing, doing this immediately helps you get up close and very personal with your car. You will find flaws, many are correctable. But once you finish you will know every inch of the car.
When I start the polishing of the car, I do jack it up take of each wheel, make sure I do the wheel wells, and the back side of the tire rims/wheels. This helps prevent getting road tar and other material embedded onto the wheel or wheel well. Normally I use the Zanio plastic or rubber protector for the wheel wells, and the Z2/Z5 for the back of the wheels. Also do the brake calibers with Zanio too.
Old May 23, 2014 | 08:53 AM
Glen e's Avatar
Glen e
I know you zaibno guys die hard so I'll just say there are now easier and equalvent gloss ways than zaino...
http://forums.corvetteforum.com/c7-g...rst-zaino.html
John Micheal Henry's Avatar
John Micheal Henry
Use the Glen e method.. Faster, easier, and better..
Old May 23, 2014 | 09:43 AM
bbrown450's Avatar
bbrown450
If you are nice and ask Glen E "Yoda" of the detail he can get you set up right the first time and this is what you can expect
Old May 23, 2014 | 10:23 AM
Glen e's Avatar
Glen e
Default No "secret"
Just good procedures new easier products and tools, email me if you want the how to docs...,.NO PMS...
Glenersly@mac.com
No scam , no sell , will email tonight....
Old May 23, 2014 | 11:37 AM
TEXHAWK0's Avatar
TEXHAWK0
Yes.... 5 minutes!
(If you can wait that long)
Old May 24, 2014 | 01:22 AM
Hebstar11's Avatar
Hebstar11
That's what I did. It looks fantastic. Car holds a lot of hidden water though.
To Waiting Period?
