Solid top v transparent top
Old May 31, 2014 | 01:31 PM
dckotwicki's Avatar
dckotwicki
Default Solid top v transparent top
Are the transparent tops any more squeaky then the solid color tops?
Old May 31, 2014 | 01:38 PM
slief's Avatar
slief
Nope. No more or less squeaky than the other. In fact the C7 roofs don't really squeak at all as far as I've heard.
Only downsides to the transparent top is a bit extra weight (several pounds) which really only factors in when you remove it or put it back on as it makes handling it by yourself a tad bit more awkward. Other factor is heat. It gets hotter to the touch during summer months making it difficult to handle when removing it and also transfers more heat into the interior which may or may not be an issue for you depending on where you live. There are now head liners available that suction cup to the inside of the roof that will help mitigate interior heat.
Old May 31, 2014 | 02:35 PM
Robert Gaspar's Avatar
Robert Gaspar
Cruising
You can eliminate the squeaks with Danco #78 O-Rings from any plumbing section. Put 2 on each of the front posts and 1 or 2 on each of the back posts. And then coat the rubber with Di-Electric grease. Voila! No squeaks.
Old May 31, 2014 | 02:39 PM
NoOne's Avatar
NoOne
It is truly transparent or tinted?
Old May 31, 2014 | 02:59 PM
BIG Dave's Avatar
BIG Dave
Heavily tinted. From the outside, almost looks black.
Old May 31, 2014 | 03:07 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Just like the C6 one. And from inside, it's tinted kinda bluish (which is good as it eliminates most - if not all - of the UV making it through)
Old May 31, 2014 | 03:15 PM
onyx_z71's Avatar
onyx_z71
I have both tops for my car and neither make any noise. If I had to have only one roof it would be the painted one, but I do like the transparent top if it's not too hot out.
Old May 31, 2014 | 03:22 PM
OperativeXIV's Avatar
OperativeXIV
Mike Furman at Criswell Chevrolet posted this thread a week or two ago that shows how to remove a top, but the C7 he uses has a clear top. This was really helpful to me in seeing what it looks like (where every google search I had turned up very little).
http://forums.corvetteforum.com/c7-g...p-feature.html
Old May 31, 2014 | 03:57 PM
14 Red Z51 Vette's Avatar
14 Red Z51 Vette
The transparent top is nice, but I would like to have the carbon fiber top for the weight difference. It can be a pita to get in and out.
Old May 31, 2014 | 08:05 PM
AFVETTE's Avatar
AFVETTE
From my 06, but they are the same today
from the outside
from the inside
And with the DSV liner installed
To Solid top v transparent top
