Lug Nuts
Old May 31, 2014 | 01:41 PM
W88fixer's Avatar
W88fixer
Default Lug Nuts
What is the size of the factory lug nuts? I’ll take my torque wrench and socket to check the lugs before taking it home, a 250 mi drive. Thanks, Don
Old May 31, 2014 | 01:58 PM
-CM-'s Avatar
-CM-
They are 19mm, and should be torqued to 100 ft/lbs.
(I have Z51 - not sure if that makes a difference.)
Old May 31, 2014 | 02:02 PM
W88fixer's Avatar
W88fixer
Thanks, knew the torque value, didn’t know the size. Don
Old May 31, 2014 | 05:39 PM
TEXHAWK0's Avatar
TEXHAWK0
A 3/4" socket is so close you probably cannot tell the difference, and may be a better fit.
Old May 31, 2014 | 06:31 PM
sharpgt's Avatar
sharpgt
Default Colored Lug Nuts
Not exactly related but anyone know where to find colored lug nuts? I'd like blue
Old Jun 2, 2014 | 11:17 PM
wgood's Avatar
wgood
3/4 " is a lot bigger than 19mm because my Z-51 ans 2005 Bonneville GXP are 19mm and my 2013 Buick La Crosse is 3/4 and you can see the difference Wayne
Old Jun 3, 2014 | 12:42 AM
kp's Avatar
kp
19mm is .748 and 3/4 is .750, good eyes if you can spot .002"
To Lug Nuts
