Learning the hard way
Old May 31, 2014 | 10:04 PM
chas70's Avatar
chas70
Default Learning the hard way
Don't ever make the stupid mistake I made. Checked oil level on my
Z51 with the engine cold. What a mess after I added 2 quarts of oil.
After a trip to the dealer and cleaning up the mess, was told I could have damaged the engine. Feel like a real idiot.
Old May 31, 2014 | 10:10 PM
slief's Avatar
slief
It certainly could have been worse. It pays to do your homework with these cars but at least you learned something and will never make that mistake again.
In the future, when in doubt search this forum. There is plenty of info and DIY instructions here to do just about anything you want on the car from DIY oil changes and other maintenance to DIY supercharger installation and most everything in between.
Old May 31, 2014 | 10:26 PM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
Better yet, when in doubt read the Owner's Manual.
Old May 31, 2014 | 11:12 PM
C7Joy's Avatar
C7Joy
I have learned to do my oil level checks after pulling into the garage from a cruise. Pop the hood, wait 5 and check.
Old Jun 1, 2014 | 10:01 PM
chas70's Avatar
chas70
Default Learned the hard way
I did read the manual but skipped right over the part about the engine being warm because after all I have always checked the oil when cold on cars for years. I won't ever take anything for granted again.
Old Jun 1, 2014 | 10:14 PM
Newstingray's Avatar
Newstingray
It's a different animal with the dry sump as you found out. Good luck with the engine.
Old Jun 2, 2014 | 11:57 AM
Chevy Cust Svc's Avatar
Chevy Cust Svc
We don't like the sound of that! Please let keep us updated on your situation, and let us know if we can be of any assistance.
Marissa
Chevrolet Customer Care
Old Jun 2, 2014 | 12:09 PM
Larry/car's Avatar
Larry/car
I have been observing some of the problems the dry sump oil system has caused some of the Forum members. The main reason I didn't order the Z51 option package was the dry sump oil system and decided on the base system (Saw no benefit for my car's projected operation). I have been around dry oil sump systems in other applications and know the special procedures associated with them. Unfortunately my first thoughts on this system are proving correct. I would like the dry sump oil system to be a stand alone selection. Now for 2015 even less item customizing, the Z51 package now has NPP as standard.
Old Jun 2, 2014 | 12:11 PM
Glen e's Avatar
Glen e
huh? I have seen no problems with the sytem posted, it's all with the owners...if you read the owners manual on how to check and drain the system, there are no problems..imagine that....
Old Jun 2, 2014 | 12:15 PM
Bill Dearborn's Avatar
Bill Dearborn
It really isn't that big of a deal. The biggest hassle is you have to get the oil up to the proper temp before you can see if you need to add any. That can be an issue if you are heading out for a track session with a cold engine so most people let the car idle for 15 to 20 minutes to heat the oil and then check it before pulling out.
Bill
To Learning the hard way
