Catch can for base car
These vehicles have a
racetrack-ready dry sump engine
lubrication system. This high
performance system operates
differently than a standard engine
lubrication system and requires a
special procedure when checking
the engine oil level. Follow this
procedure closely.
The engine oil level must be
checked when the engine is warm.
Cold oil level in the dry sump tank
may not indicate the actual amount
of oil in the system. With this
system, engine oil is contained in an
external tank, separate from the
engine. Under normal operating
conditions, the oil pan under the
engine does not store any oil. If the
vehicle has been parked for an
extended period without the engine
being started, some oil will seep
back into the oil pan, reducing the
amount of oil held in the dry sump
tank and there could be no engine
oil at all showing on the dipstick.
This is normal since the dipstick is
designed to read the engine oil level
only after the engine has run long
enough to reach normal operating
temperature. Do not add engine oil
based on cold engine dipstick
readings. The engine oil level on the
dipstick will also be inaccurate if
checked while the engine is running.
1. To obtain an accurate engine oil
level reading, warm up the
engine to at least 80°C (175°F).
Cold oil will not give a correct oil
level reading.
2. Once the engine is warm, turn
off the engine. Checking the oil
while the engine is running will
result in an incorrect oil level
reading.
3. Check the oil level between five
and 10 minutes after the engine
is shut down.
4. Remove the dipstick from the
external engine oil tank and
clean it with a lint-free paper
towel or a cloth. Re-insert the
dipstick into the external oil tank,
pushing it all the way in until it
stops.
5. Remove the dipstick from the oil
tank and read the level on the
cross-hatched area.
Capt Bob
Can’t blame GM- Ferrari and Porsche who have had high performance direct injection engines for several years are still dealing with the issue! Typically those cars are driven fast and hard, if that is not how you drive your Vette there may not be a problem. Typically those of use buying dry sump engines, Z51, drive the cars harder. A catch can is a help but requires more maintenance depending on how the car is driven. Many folks don’t follow the recommendations for checking oil level and checking a catch can would be beyond what they would probably do! GM has no doubt employed the best technology they know how and within the warrantee period there may be no issues. Perhaps we should blame the EPA for not letting crankcase blow-by go to the atmosphere like before 1960!
I have checked the oil level in my Z51 and it is spot on. I have also removed the air intake when I installed my Airaid air filter and it was spotless - no hint of oil.
Still, I plan to install a catch can and the clean oil separator. I think of it as an insurance policy to keep the MAF from getting fouled by oil should the OEM PCV valve get stuck (this has been reported already).
This is solely my recommendation and everyone can feel free to either support me or disagree with me:
Z51 - Elite's "Better" or equivalent
Either with turbo added - Elite's "Best" or equivalent
That is exactly as I see it as well. In addition I decided to keep my oil level ½ quart low, in the middle of the cross hatched area. Just means properly checking oil levels more often.
Safe, extra insurance. And your C6, like mine, used port injection that had gasoline with cleaning additives washing the intake and the back of the valves, the C7 does not!
To that end, the first thing I am adding to my Z51 (picked up this coming Mon.) is a UPR Catch can system. But any system is better than NO Catch Can.
Any vehicle with the PCV systems blows oil through to the intake. On DI engines, nothing cleans this blow-by, when it passes into the engine from the intake thru the intake valves. In a manifold FI engine, at least the fuel somewhat cleans off the intake valves. In a DI engine, there is nothing to clean the valve tops, which means the oil will bake and cake onto the valve stems.
I owned a BMW 533i (83') that had Bosch FI, which cut fuel flow to a minimum when you let off the gas. Because carbon would build up on the intake valve stems, even with the fuel spray supposedly cleaning them, the carbon on the valves would absorb the small amount of fuel, causing the engine to quit. With the stick that I owned, it was mostly annoying. However, those that had automatics, had to put their vehicles in neutral and re-start the engine, while driving wherever, like on a fast interstate. Caused many accidents!!!
After the second valve cleaning with ground walnut shells (YES REALLY WALNUT SHELLS!!!) the stretch bolts on the engine had to be replaced... as they had stretched 2" and had bottomed out in the block, and caused the head gasket to blow....
I dpn't think we will see these issues in our Vettes, BUT... for a small $$$ investment, why not buy a catch can for your pride and joy????
