Auto pull down on rear hatch?
Old Jun 19, 2014 | 02:05 AM
  #41
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Originally Posted by ~Stingray
That auto latch was awesome. Could you install one from a C6?
What's this? What's this?
A suggestion that there is something better on the C6 than on the C7??
Amazing!
Old Jun 19, 2014 | 04:22 AM
  #42
SCM_Crash's Avatar
SCM_Crash
I'd love to pull apart the memory wire system and see if I could make it work. Apparently, it was something GM didn't test before sending the vehicle on its way to the showrooms.
Old Jun 19, 2014 | 06:12 AM
  #43
Slynky's Avatar
Slynky
One thing for sure, I'd never make a habit of pushing down on a painted part of the rear hatch to complete closure--a couple years of that and you can see damage done to the paint in that area.
Old Jun 19, 2014 | 10:38 AM
  #44
FEEDMESLURPIES's Avatar
FEEDMESLURPIES
I wouldn't be surprised to see this redesigned or changed by 2016 models (or ninja changed on 2015s).
The convertibles don't have/use this, correct?
Old Jun 19, 2014 | 01:34 PM
  #45
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Hi, mine works but the vent is just not big enough. Saw a picture of it coiled as a spring someone posted, it's bigger than I expected. If you want to see if your vent opens, remove the license plate. There is a large rectangular opening behind it. Use a flashlight, stoop down and shine a flashlight in the opening. Hit the hatch switch above the license plate and watch the vent open. Believe it is doing what it is designed to do, it’s just not big enough for some cars! It is pretty big, however. Perhaps as some folks mention it is how much force is needed to squeeze the molding, some cars more than others.
Old Jun 19, 2014 | 02:06 PM
  #46
aj98's Avatar
aj98
Originally Posted by -CM-
This would be a good fix. After 8 months/6500 miles, mine still has to be slammed unless a door or window is open.
Thats what I thought too....
This is what works on mine:
With the hatch open, note there is a grab handle off centered to the right. Lower the hatch all the way.
Put the palm of your hand over the location of that handle and push down firmly.
Both sides will properly latch, neither slam nor indexed window required..
(Centering my hand on the hatch usually results in one side or the other failing to latch)
YMMV and all those disclaimers
Old Jun 19, 2014 | 02:26 PM
  #47
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by Bigdog9586
What can that auto hatch add? 2 or 3 pounds tops?
I read somewhere that they saved 1 lb. Whoopee. Think of all the hours they spent developing this.
Old Jun 19, 2014 | 02:48 PM
  #48
sharpgt's Avatar
sharpgt
A pound here and a pound there all add up. Porsche and other exotic manufacturers burn the midnight oil to save ounces. Kudos to the Chevrolet Corvette Engineering Team!
Old Jun 19, 2014 | 02:56 PM
  #49
arcticblast
Spoken like someone who has never tried to shut the hatch on a Stingray Coupe.
Old Jun 19, 2014 | 03:26 PM
  #50
DriveCorvette's Avatar
DriveCorvette
Originally Posted by David Luvy Russell
I was wondering if the C7 has the auto rear hatch pull down option? My '04 and '09 both had it but my '14 doesn't seem to have it installed or possibly its not working. So, before I take it to dealer I was just checking to see if it is an option.
Are you sure your 09 had a motorized pull down hatch? My 2008 didn't have it. I thought GM did away with it after MY 2007.
Old Jun 19, 2014 | 03:28 PM
  #51
DriveCorvette
Save ounces? C7 is a porker its heavier than a C6.
Old Jun 19, 2014 | 04:46 PM
  #52
arcticblast
I think it was part of an option package, like 3LT. I had it on most of my C6's, clear up to a 13 GS (4LT).
Old Jun 20, 2014 | 04:51 AM
  #53
SCM_Crash's Avatar
SCM_Crash
I don't believe mine works at all... With just 1 window slightly cracked (less than 1 cm) the hatch closes perfectly. With both windows up, the hatch won't even shut being slammed. I have to push down on it to get it to latch.
Old Jun 20, 2014 | 06:20 AM
  #54
JerryU's Avatar
JerryU
Easy to check if the vent is opening, as I describe. I felt the same way because it closes so easy with the door open. Very little force required. Post if you find it opens. Perhaps there is a problem with the open area inside the car, before the vent. No one has reported that and I have only seen pics of the rear, which is wide open to the atmosphere.
Old Jun 20, 2014 | 06:37 AM
  #55
JerryU's Avatar
JerryU
Just found a picture of the Memory Wire spring and the interior vent. Sure looks like more area than a 1 cm (0.4 inch) window opening!! Don't have one of the outside but you can easily see it when you look through the rectangular opening behind the license plate. Pics with the bumper removed do show a lot of open area. Looks like it's wide open.
Old Jun 20, 2014 | 07:53 AM
  #56
rcooper's Avatar
rcooper
St. Jude Donor '15
I have an 09 base, 1lt and it has the pull down for the hatch. Come om Chevy, go back to low tech.
Old Jun 20, 2014 | 11:22 AM
  #57
dbdave's Avatar
dbdave
So because some cars seem to work better than others, is it the alignment of the hatch, the gaskets, how well the doors seal, the environment the car is in, how many times the hatch is used, or something else that makes some of them work and not others? I'm assuming the hatch vent thing is the same on all of the cars so there has to be something different from car to car.
It would seem to me that something like a reed valve on a two-stroke motor would work as an air pressure relief just as well or better for a lot less technology.
To Auto pull down on rear hatch?
Old Jun 20, 2014 | 11:54 AM
  #58
bnall40's Avatar
bnall40
I agree Dave! It is an allusive aggravating problem. For me, the door always has to be open. Somehow, someway, a lot of air has to escape. I wonder if anyone has correlated the HVAV settings? Maybe the idea is off the chart but something is different from car to car.
Sam
Old Jun 20, 2014 | 09:49 PM
  #59
Dogleg09's Avatar
Dogleg09
Yes I am sure it had it, that's why I was the C7 didn't have it.
Old Jun 20, 2014 | 10:02 PM
  #60
Mfserge's Avatar
Mfserge
GM didn't test it's??? You've got to be joking because that's an outlandish statement.
