Rev Match
Old Jun 19, 2014 | 05:59 PM
drace99's Avatar
drace99
Default Rev Match
The more I drive my C7, the more I like Rev match...Does anyone know if there is a way to make the Rev Match default always on when I start the car instead of sometimes forgetting to turn it on.(I did a search but didn't see it so don't yell at me)
Old Jun 19, 2014 | 06:05 PM
Q8 c7's Avatar
Q8 c7
Opposite you,i feel it revs too high when shifting down,i didnt feel it was any good for street use.
Maybe it may help on the track and it might be better.
Old Jun 19, 2014 | 06:21 PM
Bill B 1's Avatar
Bill B 1
I don't think it is possible but could be wrong.
Old Jun 19, 2014 | 06:29 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Can't be done with the current firmware.
On a side note, I am glad to hear that "Rev match" isn't a discussion about a dating service for Ministers....
Old Jun 19, 2014 | 06:43 PM
nygsvert's Avatar
nygsvert
I just picked up my aw stingray coupe recently and thought the same. I put it to rest myself by realizing that maybe there is a good reason why Gm designed the rev match feature to be turned off in default.
1) on a cold start it would be better not to blip the throttle to a high rev while the engine is cold, especially in cold temps.
2) it will have an impact on gas mileage, I had a 2012 370Z NISMO with this feature and saw a noticeable difference in mpg with this feature turned on or off.
3) some folks prefer heel & toe technique
4) Does flipping a paddle once cause too much inconvenience?
Old Jun 19, 2014 | 06:51 PM
flaagan's Avatar
flaagan
CF "Young" Senior Member
St. Jude Donor '12
I really want to like it, but it makes downshifting to decel nearly impossible, and actually revs too high in my opinion. I want to like it, but it feels like it's getting in the way a bit too much. If I could set it to just enable for upshifts I'd love it. I've heard some folks give it rave reviews after taking the Spring Mountain driver course, something I may do, so we'll see.
As it is, I'm still getting used to the clutch engaging 'so far out' on such a light clutch pedal. Coming from a manual C4 with a heavy clutch pedal, it's a whole different experience for me as far as engaging first gear from a dead stop.
Old Jun 19, 2014 | 07:14 PM
lane7711's Avatar
lane7711
I've done heels toe at spring mountain. I will take rev match all day long on the the track or on the street. I think it is one of the outstanding feature of the c7!
Old Jun 19, 2014 | 07:41 PM
stevebz06's Avatar
stevebz06
What I have wondered, is it possible to accidentally disengage rev matching in the heat of the moment while trying to steer and shift? I mean, I've accidentally turned on windshield wipers doing this, and the paddle is in the same general area.
Old Jun 19, 2014 | 08:08 PM
gwalsh88's Avatar
gwalsh88
Old Jun 19, 2014 | 08:22 PM
mfear's Avatar
mfear
it works great on the BMW M6, too.
Old Jun 19, 2014 | 09:24 PM
Larry/car's Avatar
Larry/car
Depending on the situation rev match needs to be cycled on or off. Using the engine to slow the car, rev match off. Taking a turn at moderate performance (or more) rev match on, enhances acceleration out of the corner. After taking that corner leave rev match on as you up shift, enables a smooth gear change and increased acceleration. Seems the computer samples various parameters; gear shift/clutch engagement to rev the engine. I am still experimenting to achieve optimum utilization, one thing for sure the rev match feature can't be left on (you don't heel/toe every shift either).
Old Jun 19, 2014 | 09:42 PM
ziominix's Avatar
ziominix
I have rev matched by downshifts for years and do it subconsciously, however I find this system gets it spot on. If you feel it's revving too high, you're probably letting the clutch out too slow. If you shift quickly you'll find it's on the money. This is especially useful in every day driving when skipping several gears such as passing on the highway-7th to 4th.
Old Jun 19, 2014 | 09:57 PM
golfbone's Avatar
golfbone
The only problem I have is that I sometimes downshift into a turn to let the engine slow the car down and with rev match I get into the turn too quick and then have to hit my brakes which can be a bit dicey.
Old Jun 20, 2014 | 07:23 AM
JerryU's Avatar
JerryU
E-Ray, 3LZ, ZER, LIFT
Agree, great feature. There is no way to have it come on automatically (probably a lawyer issue!) I use it all the time and find it is a great match and not over reving as some indicate. At moderate throttle, where heel toeing is more difficult to get a perfect match, it works great, in my opinion. Perhaps if racing when you are near max rpm it is different.
Old Jun 20, 2014 | 08:03 AM
saadooness's Avatar
saadooness
Anyone experiencing a nasty scratching clunk noise underneath the gearbox when downshifing hard into a gear with rev match enabled? I may need to take her in for a check up, im worried my clutch could be damaged.
Old Jun 20, 2014 | 08:04 AM
Rich427's Avatar
Rich427
The Rev Match was design to assist you in engine braking, but I don't believe engine braking should be used to eliminate your brakes. If you are going slow enough, your brakes may not be needed, but if they are, just a little light brake pressure, then make your downshift, execute your turn and power out of the turn.
If you want to really see how well this works you have to experience Spring Mountain.
Old Jun 20, 2014 | 08:10 AM
Steve Dallas's Avatar
Steve Dallas
I've used rev match on & off. Now that I've learned the gearing, I tend to not use it at all. It can be nice for some 3rd to 2nd shifts if you're feeling lazy...most of the time I'm not.
It doesn't over-rev...it just revs for longer than needed if you were doing it yourself. Also, if you're slipping the clutch a little, the RPM's will stay the same as though the speed control was on, though you might normally be expecting it to engine brake....that doesn't happen until you fully let off the clutch pedal. I did this once slowing down behind someone, and not having the car slow down as I would expect when manually downshifting was a little weird.
To Rev Match
Old Jun 20, 2014 | 08:22 AM
Rubber Ducky's Avatar
Rubber Ducky
There's a tiny timing issue with rev match in the C7 MT. It's good, not perfect, and a very slight delay before hitting the gas (up or down) will make the whole thing smoother.
Better than heel-n-toe? If you're someone who's absolutely mastered h-n-t, you'll always prefer it ... because you can do it and that's a macho big deal. If you think it a gigantic pain (even if you can do it ok), rev match is infinitely better. Me, I can do heel-and-toe if I have to ... but I'd rather eat my own liver than do it all day all the time.
Old Jun 20, 2014 | 08:27 AM
Corgidog1's Avatar
Corgidog1
I always try to acknowledge a good line and that, Mr. Horse, is a good line.
Old Jun 20, 2014 | 08:40 AM
Q8 c7's Avatar
Q8 c7
Happened...used rev match 5 times only,i dont see it any good for me on the street
