At 500 miles, mine is down about 1/16 on an inch from when I checked it at purchase. I would say normal use. My engine has not operated in 4 cylinder mode, yet (seven speed manual).
We picked ours up on 6/13 and have been driving back across country. I did notice at the second gas stop that it was down about a quart, so I added one and bought a second just in case. But ever since it appears to have stabilized and hasn't needed any more.
Typical for new engines to burn some during the first hours of operation.
I don't think some oil burning initially is normal. With today's materials, finishes and manufacturing techniques there is no breaking-in anymore except maybe to break-in the new owner. Cylinder walls are finished to a specified roughness average and rings are lapped during mfg. process.
Today's engines can be safely operated at sustained full power output from the day they are new.
I am far from an expert.
I have owned 3 BMW motorcycles.
The first was a 4 cylinder liquid cooled "K"bike. No oil consumption.
The second was a 2 cylinder boxer. The dealer (and forum) told me that it would use oil until the hardened rings wore in. it took about 10K miles and oil usage stopped.
The third was another 4 cylinder "K" bike with no oil consumption.
My current C6 uses none and my other vehicles don't use any.
I have read that because of the AFM, some oil consumption happens. Do not know if this is accurate or not. I would be disappointed if it were true.
One more thing on break-in and surface finish.
Although I am not a bonafide expert in the field of surface finish, I do have about 2 decades of experience in the field of metrology (measurement) including measurement of surface finish.
There is a parameter called Bearing Ratio Curve or (I think) Abbot Firestone Curve. Imagine a surface finish trace with it's peaks and valleys. The Bearing Ratio is a method of looking at the peaks and calculating that the highest peaks (to be set in the software) will wear away during the initial wear or break-in period leaving behind what is called the "Load Bearing Surface".
This is a great predictor of wear, timing for tool changes at the plant and oil retention for lubrication.
The experience I have tells me that there is and always will be a break-in period, may be shorter in time and mileage, but it is there.
The real interesting thing about all of this is that in the past you would send an engine out to be blue printed... Another term for "Make it to print". It would seem to me that todays engines, because of improved measurement and manufacturing capabilities already are blue printed.
4300 miles , non z51 , auto . I checked it a few times before my first oil change and I noticed no consumption . Pretty much stayed full , although I would not be worried if it did use a quart or so .....
If you check the manual it recommends checking the oil on break-in during every gas fillup as there may be initial oil consumption.
It's clear that the cylinder walls undergo some wear initially and can be seen easily by comparing a factory fresh cylinder with one that has some small mileage. You can clearly see the diff.
Anyone notice any unusual oil consumption with the AFM motors? I have a C7 in the pipeline and have heard / read that these engines can consume oil.
There are not 2 engines that are exactly the same. This is a mass produced engine and there will be variance in assembly tolerance. Some engines will use a little oil and that will be well within spec.
I hear you but really what is there to break-in besides time needed to get the new owner up to speed with the car? You are correct about engine blueprinting. Because of new materials technology, close tolerance manufacturing and degree to which new parts are finished now all engines leaving the factory are exactly the same. There are no Monday morning engines or plus power engines anymore, they are what they are supposed to be. Ever have anyone ask if you broke the engine in to be fast?
Diagram of modern cylinder finishing procedure. You don't have to rub peaks off anymore with a recommended break-in procedure and watch them drain out with the oil at the first oil change:
The owners manual for the C7 has a break in schedule in terms of mileage.
If you buy a 502 Ramjet crate motor the computer sets your break in by hours of operation. So yes new engines do have a break in period.
OK, are you going to break your's in for speed or gas mileage? Remember the owner's manual is written for the benefit of the average potential new owner regardless of age or knowledge level rather than any purpose GM has in gently urging a fresh new engine into regular service. Can you explain why a break-in period would be necessary? What's to be accomplished? Chevrolet didn't put any rough parts in there that need to be burnished in.
I'll quote you an example. I'm in the racing engine business for a big company here where we will build and supply around 1000 NASCAR engines by the end of this year. A couple of years ago I was a part of our Research and Development group where we built and tested different designs for maximum power and durability. I could build a complete brand new engine and put it on the dyno, heat the oil in the tank, fill the engine with hot water, prime the oil pressure, start it and immediately go to full throttle at 9500 RPM under full load and it would produce the most power right then it was ever going to make. Our engineers work with the factory engineers and we know their processes and they know all ours.
I had my first oil change this past week at 1100 miles. The car is almost eight months old so I asked the Chevy dealer to change the oil. I was concerned because the Engine Oil Life System was reading 35% but every time I checked the oil level it was right up to the top. Dealer said they would not have changed the oil if the car was less then six months old though. I guess the algorithm's are different now, as on my C6 i would go almost a year and still show around 80%. Most of my driving is about 90% around town.
5,900 miles and no oil consumption, unlike the new 2013 BMW 650i Gran Coupe that used 5 qts of 0w-30 Castrol synthetic in 15,000 miles and a BMW dealer stated "that's
normal"......
