I have never paid that much attention to it. I'm one of those drivers who grew up with annuciator lights. As long as the light isn't illuminated, good to go.
Mine fluctuates 35-50 as it is warming up. The needle in the pocket gauges fluctuates noticeably up and down at about 100-200 degrees. When complexly warmed up it is steady at about 35.
That seems really low since I'm used to a car that shows over 90psi on a cold start, runs 60psi at 2K rpm hot, and idles at 30psi hot. That's also with 5W-30.
I KNOW the engine only needs enough pressure to deliver enough oil to keep things cool, and that hydrodynamics is supposed to keep things from rubbing together, but...
I suppose going to a low pressure system is part of the quest for fuel economy, but what are they giving up in return? You gotta save a lot of gas to make up for a spun main bearing.
For what it's worth the LT1 has a variable pressure system, which is why it is low at times. This is from GM:
"The LT1 oiling system – including oil-spray piston cooling – was also optimized for improved performance. It is driven by a new, variable-displacement oil pump that enables more efficient oil delivery, per the engine’s operating conditions. Its dual-pressure control enables operation at a very efficient oil pressure at lower rpm coordinated with AFM and delivers higher pressure at higher engine speeds to provide a more robust lube system for aggressive engine operation.
Standard oil-spray piston cooling sprays the underside of each piston and the surrounding cylinder wall with an extra layer of cooling oil, via small jets located at the bottom of the cylinders. For optimal efficiency, the oil jets are used only when they are needed the most: at start-up, giving the cylinders extra lubrication that reduces noise, and at higher engine speeds, when the engine load demands, for extra cooling and greater durability."
