C7 CD Player
Old Jul 24, 2014 | 02:17 PM
RichardLord's Avatar
RichardLord
Default C7 CD Player
OK, so, if I ask who makes a portable CD player for a C7, that is a plug and play, such that I can play it in C7 sound system accessing my USB port, some of you shall lambast me for not getting past CDs. But, here's the problem. The wife and I in traveling listen to stories on CD from the local library. The C7 does not have a CD player, and we want to listen to library story CDs, and so we want to get a portable (not permanently mounted) CD player that we can plug into our C7 sound system via USB. Yes, maybe copy the stories to something I could use via my C7 USB port, but am sure my library would have a problem with that, and so we don't want to go there. So, again, without the slams about using a CD player, is there a portable CP player out there I can plug and play into my 3LT C7 sound system?
Old Jul 24, 2014 | 02:33 PM
Al Blue4.6l's Avatar
Al Blue4.6l
you should be able to play any portable CD player through the 3.5mm aux audio jack.
Old Jul 24, 2014 | 03:11 PM
mpuzach's Avatar
mpuzach
Agreed. Just use a 1/8th" stereo cable to connect the CD player's headphone output to the car's input.
Old Jul 24, 2014 | 03:20 PM
Glen e's Avatar
Glen e
Just get a portable CD player and go see a radio shack guy, tell em you want to make the CD player work. He'll get you the cord. It plugs in the center console storage area......
Mdm23's Avatar
Mdm23
Use the auxiliary jack, not the usb port. It's located in the center console.
Old Jul 24, 2014 | 04:22 PM
jerryv's Avatar
jerryv
Just rip your cds to a USB drive or an SD card. I thought I was going to hate not having a CD player, but after ripping 500 CDs onto ONE SD card, I'm in heaven. The whole library at my fingertips. And anytime you want, you can erase it all and start over .. or get another SD card loaded however you want.
But .. as already noted, you can make virtually any portable CD player work using the AUX port .. if you feeling like lugging stuff around with you.
Old Jul 24, 2014 | 04:23 PM
Tannman's Avatar
Tannman
We also like to listen to library audio books when we are on trips. But, I just download them to an SD card via iTunes and return the CD's to the library. They don't care. It works great.
Old Jul 24, 2014 | 04:53 PM
Harry2's Avatar
Harry2
[QUOTE=jerryv;1587437040]Just rip your cds to a USB drive or an SD card. I thought I was going to hate not having a CD player, but after ripping 500 CDs onto ONE SD card, I'm in heaven. The whole library at my fingertips. And anytime you want, you can erase it all and start over .. or get another SD card loaded however you want.
I agree, I am old school too and was concerned to read that the CD player had been eliminated from the C7. I then read the Forum comments, educated myself and "ripped" my CD's on to my computer, then transferred them to a SD card and could not be happier with the results. The sound quality is amazing, much better then my XM signal and the total cost of the 16 GB SD flash memory card and reader was less then $20.00.
Give it a try before you add a loose CD portable player into your C7.
Old Jul 24, 2014 | 04:57 PM
JDM111er's Avatar
JDM111er
I have 5000+ CDs burned to a portable hard drive. Its much better then a CD player
Old Jul 24, 2014 | 05:43 PM
jerryv's Avatar
jerryv
Wow .. that's a major collection. I think the total song limit is 100,000 .. so you must be getting close.
What kind of drive? USB powered, I assume?
Old Jul 24, 2014 | 07:42 PM
firemon's Avatar
firemon
Well, If you want to get a little fancyier you could get a portable DVD player as these also play CDs, And your passanger could watch a movie now and then. they take up about the same space
Old Jul 24, 2014 | 10:44 PM
Mfserge's Avatar
Mfserge
Any portable CD player will work, then buy the cable below, plug it into the CD player and the other end into the aux input in center console. A portable DVD player will work as well and so may a laptop using the headphone jack.
http://www.bestbuy.com/site/rocketfi...able&cp=1&lp=2
Old Jul 25, 2014 | 12:43 AM
brandin10's Avatar
brandin10
What is a CD?
Old Jul 25, 2014 | 08:39 PM
sdk's Avatar
sdk
Originally Posted by brandin10
What is a CD?
Certificate of Deposit.
Old Jul 26, 2014 | 12:10 AM
brandin10's Avatar
brandin10
Old Jul 26, 2014 | 03:44 AM
RichardLord
I thank all of you for your advice. Got the $20 Best Buy CD player and the appropriate wiring, and now am listing to CD audiobooks. A bit convoluted with an external CD player and wiring, but it works. This was probably not the best choice of the above comments, but I have a daily driver as does the wife, plus a utility vehicle, that have CD players but no other options. So, we are stuck with CDs for those vehicles, and as we go through a lot of CD audiobooks, I can't see burning a lot of CDs to other devices. We are constantly switching audiobooks to one vehicle or another. We are turning into radio-days people as it seems we listen to more audiobooks, as well as read books, and actually talk, than we watch TV or go to movies.
Old Jul 26, 2014 | 10:22 AM
c5eddiem's Avatar
c5eddiem
Richard,
Glad it worked out for you.
Another possibility... the public library here has audiobooks that can be downloaded and put on a usb stick. You do it over the internet from home.
Select the title
Download the book directly to USB in PC
Put in the Vette and roll.....
Don't know if it's national, but in CT the libraries have a program called Overdrive that manages your "borrowed" audiobooks. Large selection and up to 5 books out at a time.
Ed
To C7 CD Player
Old Jul 26, 2014 | 12:34 PM
brandin10's Avatar
brandin10
Originally Posted by c5eddiem
Richard,
Select the title
Ed
Richard
I also listen to audio books. I use audible.com. You can download the book of your choice to your phone. Once its on your phone you just use the Bluetooth playback option on your C7.
Old Jul 27, 2014 | 12:04 PM
c5eddiem's Avatar
c5eddiem
just to add.... the audiobooks from the library are free!
Old Jul 29, 2014 | 10:16 PM
wgood's Avatar
wgood
Well I have an AIWA CD player with EASS ( electronic anti shock sysyem ) Date on the bottom shows 1994 and it plays on batteries or if you can pick up some kind of converter from 12v to 6 volt it would play from the 12v jack !!! Again just like other things you could use the phone jack to the 3.5 mm jack !!! Good luck !!! wayne
