Anyone know?
I can't seem to find it in the manual.
Page 10-14 of the owner’s manual, 18 ft-lbs. Right below the paragraph states the oil filter torque is 22 ft-lbs.
Probably for the 1st time ever I used a torque wrench on the oil filter since I had a filter wrench that captured the base and had a 3/8 drive socket in the center. 22 ft-lbs was much more than I would use. Was concerned I would twist the gasket. Backed off and did my usual of about ¾ turn after the gasket touched and it "felt right!"
For what it’s worth, the PDF of the owner’s manual (available on the net) allows you to hit Control F and search for words like “drain plug.”
It's odd that there's not an oil change procedure for non-Z51.
Noticed that when I searched for "drain plug" in the PDF of the owners manual! Info is only for the Z51. That is where the "drain plug" words are found and the pic is the 2 plug Z51 pan.
I have been looking at the owners manual on line. I will look at the book.
