Race ramps
Old Aug 12, 2014 | 06:07 PM
firemon's Avatar
firemon
Default Race ramps
Anyone know where I can get a bargan on these ? and what size do I need ? Thanks
Old Aug 12, 2014 | 06:11 PM
v8capt's Avatar
v8capt
I sold my race ramps because the angle is such that all the oil won't drain on the base car. They work fine for the Z51 or Zo6
Old Aug 12, 2014 | 07:10 PM
Fred@ReverseLogic's Avatar
0Fred@ReverseLogic
Former Vendor
Default C7 clears RR-XT-2 Race Ramps
The air dam on a base C7 will just barely clear the 10.8 degree incline of the RR-XT-2 model Race Ramps. If you need to keep the car level while doing maintenance, consider the wheel cribs as shown in this thread:
http://forums.corvetteforum.com/c7-g...-pictures.html
The MAP price for the RR-XT-2 ramps is $334. Just about all Race Ramps resellers include free shipping. Some resellers (including Reverse Logic) offer coupon codes which lower the price a little more. The current offer at Reverse Logic is $334 less 10%. The only State we are required to charge Sales Tax in is Pennsylvania.
http://www.reverselogic.us/shop.html...0&sort=nameAsc
With the current $20 factory cash back rebate, the RR-XT-2 ramps cost just over $280.
If you want a little more clearance consider the RR-80-10-2 ramps which have an 8.5 degree incline or the RLL-80-2 ramps with a 6.8 degree incline.
http://www.reverselogic.us/shop.html...49&id=19995831
Old Aug 12, 2014 | 08:03 PM
John Micheal Henry's Avatar
John Micheal Henry
firemon, Get them from Fred.
[URL=http://s979.photobucket.com/user/fan45acp/media/DownUnder051.jpg.html][/URL
RR-XT-2 Race Ramp 2-piece 67" Long and RR-WC-10 Race Ramp 10" Wheel Cribs
Old Aug 12, 2014 | 08:32 PM
Raisin Man's Avatar
Raisin Man
I own two pair to simplify moving a few cars on / off car lifts in my garage. Didn't understand at the time Raceramps could customize ramp dimensions.
Product is good, but I would ask them to make you wider ramps. I think they make the ramps as narrow as possible to keep product costs low. Wider ramps will cost you a few more dollars, but much easier with wider tire on Corvette and other higher performance vehicles. Otherwise, margin for error moving on & off ramps is small.
Old Aug 12, 2014 | 08:41 PM
0Fred@ReverseLogic
Former Vendor
You are probably using the 12" wide Trak-Jax in conjunction with your lift. Most of the service ramps we offer are 14" wide, and all of the drive-on trailer ramps are at least 14" wide.
Old Aug 12, 2014 | 08:45 PM
HalfMoon's Avatar
HalfMoon
+1
Fred has been a forum supporter here for a long time and is always up front when answering questions.
Old Aug 12, 2014 | 09:43 PM
C7Joy's Avatar
C7Joy
I have the 10" high ramps and used them with my C6. I have not tried them with the C7 yet but they look like they will be ok. The wheel cribs look like they might be good to have too. May get a set of them.
Old Aug 12, 2014 | 09:59 PM
mjcourt's Avatar
mjcourt
If you just want to change your oil and your driveway slants downward, this is a bargain.
Old Aug 12, 2014 | 10:46 PM
zoomer96's Avatar
zoomer96
I've had my ramps for more than 30 years. When I bought my C4, I had two problems. The tires were too wide and the air dam hit the ramp. Here's how I solved both problems. I haven't had my C7 on these yet but I expect them to work just as well.
Old Aug 13, 2014 | 11:40 AM
jeffgad's Avatar
jeffgad
Don't do it! I got some and ran off the back. $2000 in car damage, and incalculable ego damage.
Old Aug 13, 2014 | 12:00 PM
0Fred@ReverseLogic
Former Vendor
Placing a wheel chock in the path of the rear tire is a good way to help prevent a car from overriding the top edge of the ramps. You need to measure the distance (equal to the wheelbase) from the stop on the ramps to a point where the rear tire will contact the wheel chock at about the same time that the front tire contacts the stop on the ramps.
Once the car is on the ramps you can reposition the wheel chock behind the rear tire.
The first time you do this you can measure the distance between the leading edge of the ramps and the wheel chock and use that shorter measurement to position the wheel chock the next time you use the ramps.
To Race ramps
