Wrong octane
Today I went to fill her up and I accidentally had a brainfart and filled her with **** (87) octane by accident. The car still had 8 gallons of 91 octane from the last fill up. Do I need to take a road trip to burn off this tank or will I be fine as long as I don't go out drag racing. I know my c6 I used 87 all the time with no apparent issues, but with the stingray being required 91 im worried. I called the dealership and they said to go to autozone and buy octane booster which I did but at 10 a pop I only got 1 bottle. Guess I will baby it for 300 miles or so
The bright side was the fill up only cost 40.00
Your profile doesn't say where you live, is it a particularily hot area? The computer will back off a lot more timing if it's 100 degrees outside compared to 75 or 80 for example. Even with 100% 91 octane it would probably pull out a few degrees of timing in 4th-7th gear if it's 100 degrees outside.
Use premium unleaded gasoline with a posted octane rating of 91 or
higher. If the octane is less than 91, you could damage the engine and
may void your vehicle warranty. If heavy knocking is heard when
using gasoline rated at 91 octane or higher, the engine needs service.
Just FYI.
Many owners forget that their C7 is a Chevrolet. It's a car. One tank of 87 octane gas won't hurt anything, yet many would buy octane boost, drive it like an old lady and keep topping off with 93 octane, etc, etc, etc.
Even though the manual preaches doom and gloom about nothing less than 91 Octane I am sure you are fine. It's not like you put diesel in the car! Just cruising you will be fine, it probably would be more of an issue at the track.
We should be more worried about properly cleaning our windshields!
Quote: (From 'there's an app for this');
<It’s perfectly fine to combine different octane levels of gas, as long as they’re both unleaded. The only difference between the two blends is their octane content. It’s like if you had really sweet iced coffee and an only slightly sweetened batch of ice coffee and you wanted just a middle level of sweetness coffee and did it by making a blend of the two. It’s all the same coffee, only the sugar levels are different.>
As long as you're not flooring it or lugging it (where detonation may be a factor), it makes absolutely no difference to the engine. On long trips with highway cruising only (no racing), you can run regular for all the engine cares...what does it take at 75 mph, 15 horse power?
No, I'm not recommending anyone run cheap gas. Just making the point that it is not the end of the world. As long as you're not pushing detonation, the engine doesn't know or care what grade fuel you use.
