Low Fuel Warning.
Old Aug 22, 2014 | 08:49 AM
stingraymyway's Avatar
stingraymyway
From: Out of Site...Out of Mind. Corvette: anything else is just transportation.
St. Jude Donor '09 thru '20
Default Low Fuel Warning.
Wasn't paying attention to the gas gauge when I saw the low fuel level warning.
What's the amount/range after that appears?
Anyone push the limit?
Old Aug 22, 2014 | 08:52 AM
sandu002's Avatar
sandu002
I believe it is telling you how many miles you have left before you run out of gas. I have pushed mine till it said I had 15 miles left.
Old Aug 22, 2014 | 09:00 AM
z51vett's Avatar
z51vett
At 15 miles left how many gallons to fill up.
z51vett
Doug
Old Aug 22, 2014 | 09:01 AM
chevyman426's Avatar
chevyman426
z51vett
Doug
One gallon or less!
Old Aug 22, 2014 | 09:03 AM
sandu002's Avatar
sandu002
I was running a road rally at the time and only put in about half a tank to get me thru the last two checkpoints.
Old Aug 22, 2014 | 12:00 PM
BigJoe's Avatar
BigJoe
I think you have about 40 miles of normal road driving left to empty when you see that. About 2 gallons. Less if you are racing...
Last time I saw it, conveniently right next to a gas station, I had to put in a bit over 16 gallons to fill it up.
Old Aug 22, 2014 | 01:35 PM
W88fixer's Avatar
W88fixer
Playing that game in the summer could be expensive. The fuel pump uses gas to cool itself. Run the car too low for too long or too often can kill the pump. Even if your car is under warranty (of course a C7 will be), you want to get stranded in East Jesus?
What’s the rationale for pushing the limit? Fill up and move on. Don
Old Aug 22, 2014 | 08:24 PM
sdk's Avatar
sdk
The warning came on for me and said I had 50 miles left. Yes, I drove it until the warning came up because I wanted to know how many miles I would have before running out.
Old Aug 22, 2014 | 08:30 PM
runutzzzzz's Avatar
runutzzzzz
IIRC, it states 50 miles till empty. I've driven some 75 miles after the light has come on and when I filled up, I still had a gallon left in the tank or so.
MFGs will always underestimate the remaining miles till empty. Usually when you get to 0 Miles, you usually have 1-2 gallons left.
Old Aug 22, 2014 | 08:31 PM
Modshack's Avatar
Modshack
Yup...Mine comes on at 40 miles left.....Wish it did the full countdown like most cars....I was in he boonies with 30 miles to the nearest station...Made it!
Old Aug 22, 2014 | 09:52 PM
Dave80C3's Avatar
Dave80C3
Headed north I was not paying attention this spring. The low Fuel light came on, said I had 40 miles. GPS in car said 48 miles to next gas. Well I drove 7 miles after 0 miles left. I put just over 17 gallons in the tank.
That is the one and only time I have seen the low fuel light. I do not plan to ever see it again
Old Aug 23, 2014 | 06:05 AM
stingraymyway
I usually find a gas station when it reads 1/4 tank left.
Old Aug 23, 2014 | 07:02 AM
crazybiker51's Avatar
crazybiker51
Usually lights come on at 30miles with most vehicles, my cts v however would give a warning at about 15, once it came on for good you had best be in sight of a gas station; good old gm
Old Aug 23, 2014 | 07:22 AM
mksz51's Avatar
mksz51
It irritates the heck out of my wife. That can be entertaining - or not.
Old Aug 23, 2014 | 09:49 AM
W88fixer's Avatar
W88fixer
Bear baiting has it’s risks! Don
Old Aug 23, 2014 | 01:18 PM
TEXHAWK0's Avatar
TEXHAWK0
The fuel gauge is the size and shape so that the curved part is perfectly hidden from my view by the steering wheel, so I almost ran mine out of gas once...
Now I keep the information center set on gallons used to remind me when I need to refuel....
I think I still had at least 2 gallons when the light came on.
Old Aug 23, 2014 | 02:34 PM
Steve Dallas's Avatar
Steve Dallas
Yes, 50 miles has always been when it's come on for me.
To Low Fuel Warning.
