Window Cleaning ?
Old Sep 3, 2014 | 09:44 AM
btorlv's Avatar
btorlv
Default Window Cleaning ?
What to you use to clean the windshield where it meets the dash around the heads up display? I use a towel with invisible glass cleaner on all my glass and the glass still looks like it has a film left on it.
Old Sep 3, 2014 | 12:06 PM
HDBADDOG55's Avatar
HDBADDOG55
One part rubbing alcohol, three parts water, mix in spray bottle. Spray solution onto clean wash cloth, apply to your window glass, wipe off with dry micro fiber towel. Haze/film will be history.
Old Sep 3, 2014 | 01:12 PM
AFVETTE's Avatar
AFVETTE
I've given up until I bought some ZAINO Z-12 Glass Polish.
But there are other products and tricks folks will recommend.
Good luck
Tom
Old Sep 3, 2014 | 01:19 PM
USAF's Avatar
USAF
isopropyl alcohol 50%
USAF
Old Sep 3, 2014 | 07:51 PM
wgood's Avatar
wgood
I use Quik N Brite and light to clean the hatch glass inside and heavy for other areas !!! Wayne
Old Sep 3, 2014 | 09:42 PM
Larry/car's Avatar
Larry/car
GM glass cleaner, works extremely well and will not harm acrylic roof panel.
Old Sep 4, 2014 | 12:33 AM
C2C3C4C6's Avatar
C2C3C4C6
I use water (from an Ionator) and a Tupperware microfiber towel; the towel is the key. I have used many products over the years but nothing can compare to the results with this towel.
Old Sep 4, 2014 | 05:52 AM
lgodom's Avatar
lgodom
The trick to using invisible glass is to follow the directions and clean the windows twice. I've never gotten satisfactory results
using it once. It really takes the second application to get the glass clean .
Old Sep 8, 2014 | 11:01 AM
Scooter NYY's Avatar
Scooter NYY
Just use a moderately used, but very clean terry cloth towel on the inside of the glass.
You don't need any type of chemical cleaner. I am a chemical engineer by education and any type of chemical cleaner will leave a residue on the glass unless cleaned off completely with a clean dry cloth. Don't even bother with the chemicals, in other words.
Old Sep 8, 2014 | 11:05 AM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I use these - better than ANYTHING else I've ever used and I absolutely swear by them now
http://www.rpidesigns.com/shop/item.aspx?itemid=3273
Old Sep 8, 2014 | 12:21 PM
Bigredwing's Avatar
Bigredwing
I use that stuff too and have found that I need two towels. One to apply and clean, and the other to polish off the haze. I have a feeling that Stoner changed their formula because when it first came out and I started using it I didn't have this issue. Still recommend it though.
To Window Cleaning ?
