HUD memory question
Old Sep 11, 2014 | 11:01 AM
Heidemarie's Avatar
Heidemarie
Default HUD memory question
Can anybody explain why the HUD returns to just "mileage 0" display after engine is turned off. We have to manually reset it each time with engine start to desired display. Cannot find any instructions in owner's manual on how to safe HUD setting in memory so it remains in the selected setting from previous ride.
If HUD memory can be achieved, please give detailed instructions on what menu to access and how to auto recall that preset HUD. Appreciate any help in this regard. Never had this problem in our C6 but this C7 computer system is totally different, of course.
Thanks in advance Heidemarie
Old Sep 11, 2014 | 05:44 PM
tentorium's Avatar
tentorium
Are you saying when you start up that the display on the windshield is a "0"? If yes, this is the look of the HUD in Touring mode. HUD will morph with driving mode selected.
Do you have auto transmission? I do and Touring is the default mode for each ignition cycle unless I shut down in Sport mode.
Old Sep 11, 2014 | 06:24 PM
owc6's Avatar
owc6
I always shut down in sport mode (set on track HUD), but randomly, every 6-10 cycles it will revert to sport mode HUD display upon start-up. I can find no pattern to it.
Old Sep 11, 2014 | 06:36 PM
tentorium's Avatar
tentorium
Yeah it's not always symmetrical- same thing with using the mode selector. Even though I know exactly how fast/slow to turn, it sometimes goes in the opposite direction I want it to.
Old Sep 11, 2014 | 07:11 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Only if you have Driving Mode linked to the display. If not linked then the HUD will remain where it was at shutdown.
I don't have mine linked and generally keep things in Tour Mode and the HUD always comes up where I left it last (circular tach, lateral g-force indicator and speedo). Oh yea, '14 M7 VIN 11822
Old Sep 11, 2014 | 09:17 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
My driver mode is not linked and I experience same thing as OP. After like 10-20 fresh startups, it changes to sport on te HUD display. No rhyme or reason..
Old Sep 11, 2014 | 09:39 PM
CaryKen's Avatar
CaryKen
Just adding another data point to the collection. Mine does the same thing. M7, unlinked to drive mode. Occasionally starts up in Touring Mode display, even though I shut off the engine in the usual "dogleg tach" display. I can also confirm the occasional misdirection on choosing the driving mode with the dial selector. Turn it "up" and the mode goes "down". I would say each condition happens with perhaps 5-10% frequency of total use.
I also had the entire infotainment system freeze, turn off, and reboot. It did this once, while the engine was running and it was attempting to recalculate a nav route after I made a turn. It worked fine after its self-imposed reboot (took about 2-3 minutes, subjective and approximate).
Old Sep 11, 2014 | 09:47 PM
FYREANT's Avatar
FYREANT
I'm Batman..
Pro Mechanic
Thats happened to a few of us, including me. I was going 80 on the highway when everything rebooted..
Old Sep 12, 2014 | 11:23 AM
JandDsC5's Avatar
JandDsC5
Active Streak: 90 Days
Another with same experience as OP. Built 7/25/14.
Old Sep 13, 2014 | 08:59 AM
Heidemarie's Avatar
Heidemarie
Yes A8. Thanks to everyone chiming in; looks like a small computer memory glitch. I guess we will continue changing HUD to desired display each time we start the engine. We do mostly touring mode right now; have only 225 miles on odometer so far and need to break in engine still. You guys are awsome appreciate all the replies.
Heidemarie
Old Sep 13, 2014 | 09:03 AM
sotirisf's Avatar
sotirisf
'Yeah it's not always symmetrical- same thing with using the mode selector. Even though I know exactly how fast/slow to turn, it sometimes goes in the opposite direction I want it to. '
'I always shut down in sport mode (set on track HUD), but randomly, every 6-10 cycles it will revert to sport mode HUD display upon start-up. I can find no pattern to it.'
Yup, I have those two instances happening to my A6 Z51.
Dealer cant replicate when I brought it in for service.
Nice to know its not only mine...
Old Dec 24, 2014 | 10:01 AM
CaryKen's Avatar
CaryKen
Just bumping this three months on... Anybody heard of a flash fix? Do we think GM is aware of the problem? I just took it to my dealer to get the expected "Can't replicate. No fix."
Old Dec 24, 2014 | 10:30 AM
Cruiter's Avatar
Cruiter
On order: Torch Red Z51
Same here, I've not been to bothered by it tho as it's the way of computers. And anything on our cars now that's not mechanical is part of a computer.
Old Dec 24, 2014 | 11:15 AM
Len44's Avatar
Len44
Sure sounds to me like this PITA is worthy of a response / fix from GM.
Anybody from Customer Service want to chime in here?
To HUD memory question
