C7 Body Control Module (BCM)
Old Sep 12, 2014 | 03:33 PM
spaceaholic's Avatar
spaceaholic
Default C7 Body Control Module (BCM)
Anybody know where its located, and where I might obtain a spare/replacement?
Old Sep 12, 2014 | 03:35 PM
Zymurgy's Avatar
Zymurgy
Moderator
Should be able to order one from any of the GM parts suppliers. Suggest our forum parts suppliers. Probably not cheap.
Inquiring minds want to know: Why do you need one?
Old Sep 12, 2014 | 03:38 PM
spaceaholic
Wipers are inoperable, no voltage from the BCM
Old Sep 12, 2014 | 03:39 PM
DocGuy's Avatar
DocGuy
St. Jude Donor '15
According to my tour guide during my delivery tour, it is the box, about the size of a shoe box, that is attached to the rear of the car, drivers side, under the black part of the facia...hope this helps...
Old Sep 12, 2014 | 03:40 PM
spaceaholic
Hmmm...ok will take a look. Thanks
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
The dealer handling your warranty replacement can't get one?
Old Sep 12, 2014 | 03:42 PM
spaceaholic
Probably not (under warranty)....vehicle has A&A SC/Meth Kit/ARH LT's installed
Old Sep 12, 2014 | 03:43 PM
KenHorse's Avatar
KenHorse
(understatement) That sux.....
Old Sep 12, 2014 | 03:53 PM
Zymurgy's Avatar
Zymurgy
Moderator
Your mods should not void your warranty on the BCM. Powertrain - Yes.
Old Sep 12, 2014 | 04:56 PM
Zymurgy's Avatar
Zymurgy
Moderator
I assume you have checked Fuse #1 in the under hood fuse box? Also #'s 16, 18, 20, 54 and 56.
In the rear fuse box - #'s 7, 10, 15, 16 and 19.
Old Jan 26, 2020 | 04:54 PM
kenthomas4's Avatar
kenthomas4
how can you check 54 and 56?
Old Jan 26, 2020 | 05:20 PM
ersatz928's Avatar
ersatz928
The BCM is located in the passenger footwell, behind the carpet, where the feet are. The BCM is attached to the silver metal plate.
Old Jan 26, 2020 | 07:20 PM
KenHorse's Avatar
KenHorse
He's been working on it for 6 years. I hope he's found the problem by now
(Damn Related Threads strikes yet again)
Old Jan 26, 2020 | 07:28 PM
DALE#3's Avatar
DALE#3
Old Jan 26, 2020 | 09:16 PM
May be an old thread but we have two different locations being mentioned for the BCM. So, which one is it?
Old Jan 27, 2020 | 10:39 AM
kenthomas4's Avatar
kenthomas4
I know, I hijacked this thread. I went back and checked the fuses listed above. My specific question is how can you check the block fuses? 54 and 56 were listed but there is no indicator if they are blown.
I do not think the BCM is fried; wipers still work and was told the BCM controls them?
Old Jan 27, 2020 | 01:44 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
BCM is located in the Passenger footwell, under the carpet.
Elmer
To C7 Body Control Module (BCM)
