I could use some advice. I will be taking delivery of a new C7 at the museum in Bowling Green. I live in MN so I have about an 800 mile drive home. I do not have the time to do the back road thing and really would prefer using the interstates. Will I hurt the engine by breaking it in this way? I have read all about varying the speed, not exceeding 4000 rpm etc but in the interest of safety I am not going to be able to put much variability in speed when I am on the freeways. Thoughts? Thx!
I could yes some advice. I will be taking delivery of a new C7 at the museum in Bowling Green. I live in MN so I have about an 800 mile drive home. I do not have the time to do the back road thing and really would prefer our the interstates. Will I hurt the engine by braking it in this way? I have read all about varying the speed, not exceeding 4000 rpm etc but in the interest of safety I am not going to be able to put much variability in speed when I am on the freeways. Thoughts? Thx!
Auto or manual....whatever do this. With auto, use paddles.
Get up to interstate speed for cruise, go to your top gear for 15 min, then shift down to next lower gear for 15 min, then next lower for 15... Then do the same back up. Its all sbout changing rev's, not speed. Do for 500 miles....done.
Get up to interstate speed for cruise, go to your top gear for 15 min, then shift down to next lower gear for 15 min, then next lower for 15... Then do the same back up. Its all sbout chsnging rev's, not speed. Do for 500 miles....done.
Awesome advice - I must have cob webs in the brain - I don't know why I did not think of that. Thanks so much! It is a manual which makes your advice easy to follow.
Probably driving home "without" using cruise will do it for you, if you don't use cruise your speed will vary, just keeping up with the traffic should give you no choice to drive at all speeds.
I broke mine in around town then I took a little 300 mile trip at the end, your just taking your trip at the beginning.
You might want to pick up a bra for that 800 mile drive. Nothing worse than washing your new vette when you get home just to find nicks and rock chips.
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
with all the advice above except pick up a couple rolls of painters tape (the blue "masking tape") and cover the vulnerable areas with that. It'll take less than 30 minutes to apply and cost less than $20 to do. Oh yea, don't forget the mirror fronts and front quarters
The engine is ready to go out the door. Engine building has came a long way. You can lay a 100' burnout out that parking lot. No break in is needed. With todays oils and advanced rings, pistons, crank balance and better tolerances. It's ready.
Now are dealers going to say "it's good, go for it" probably not, but it is.
Example I just built a 750 HP 406. Started it ran at 3k RPM 2 minutes drove for 1 mile. Did a tune on it and then to the track for a 8500 rpm pass at 130 mph at 10.6 seconds.
Break in involves more than just the engine....
The OP would be well advised to follow GM's recommendations about breaking in his new C7....
I drove mine home 430 miles...
LOL. You and I think alike. I taped up the front of my C6 with painters tape on the long drive home when I first bought it. Looks funny and gets some stares but better than coming home with chips on a new car. .
I won't have to drive that far home this time and will be taking back streets when I pick up my C7. I do have to drive about an hour to where I plan to get the clear bra installed so I'll have to do the drive of shame with the painters tape one more time.
I think the break-in is more for the clutch, gear sets in the trans and the rear diff.
