Vin # ?
Old Oct 6, 2014 | 09:14 AM
dprestidge's Avatar
dprestidge
Default Vin # ?
I am looking at a used C7 and need to use the vin # to check opts. Can someone tell me if there is a site or something to do that.
dp
Old Oct 6, 2014 | 09:23 AM
runutzzzzz's Avatar
runutzzzzz
dp
Won't tell you the exact options but will tell you a little info.
Ask the seller to take a pic of the RPO sticker in the back under the carpet where the fuse box is.
https://www.corvetteforum.com/forums...post1584799041
2014 VIN Decoding:
This is an example of a VIN # for a 2014 Corvette Coupe (3LT, Z51, MN7):
1 G 1 Y L 2 D 7 X E 5 1 0 0 0 0 1
There are 17 characters. Starting with first character on left the codes are:
01. "1"= Built in US
02. "G"= General Motors
03. "1"= Chevrolet
04. Denotes the car line: Corvette is a "Y" body.
05. Provides more info about the car:
.. A=1LT M/T
.. B=1LT A/T
.. C=2LT M/T
.. D=2LT A/T
.. E=3LT M/T
.. F=3LT A/T
.. G=Z51 1LT M/T
.. H=Z51 1LT A/T
.. J=Z51 2LT M/T
.. K=Z51 2LT A/T
.. L=Z51 3LT M/T
.. M=Z51 3LT A/T
.. 9=export (Non US, Non Canada)
06. Body style: "2" = Coupe, "3" = Convertible
07. Restraint code: D – AJ7 Active Manual Belts, Airbags – Driver & Passenger and Seat Side
08. Engine: LT1 = "7"
09. Check Digit – 0 to 9 or X
10. Model year: E (2014)
11. Plant: Bowling Green = "5"
12-17. Production sequence number that starts with the #100001 for each model yr.
Old Oct 6, 2014 | 09:50 AM
CaryBob's Avatar
CaryBob
Right. All the options are listed on that sticker. It's really the easiest way to check on the details of how the car was configured when it left the factory. You can then look up the RPO codes in the Order Guide, which is linked with a sticky at the top of this forum.
To Vin # ?
