Brake dust!
Old Oct 13, 2014 | 09:13 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Originally Posted by ELEV66RG
Thanks for the recommendation. I will probably look into the ceramic pads. I'm definitely not tracking the car. Will ceramic aftermarket pads void any warrantee?
If you would like a set of the Carbotech 1521 give me a call at 216-780-8825.
$325 for front and rear total.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Oct 13, 2014 | 10:11 AM
b4i4getit's Avatar
b4i4getit
Since the vast majority of C7's will not be tracked and brake dust is always a problem, why doesn't GM step up and install some other pads as stock equipment. ?
Old Oct 13, 2014 | 10:24 AM
Larry/car's Avatar
Larry/car
The base car's brake pads do not deposit excessive brake dust on wheels. Fact is, less brake grime than my previous C6's base system.
Old Oct 13, 2014 | 11:16 AM
RCB1234's Avatar
RCB1234
Default Changing Pads
I have had my 2015 2LT Z51 for two weeks now and have put 500 local miles on it. The car is terrific but I can't get over the brake dust accumulation. Everything appears to be functioning normal. I have never before been so compulsive on keeping my vehicles spotless. Is the brake dust normal?
Is there a Video out there that shows how to change the brake pads on the Z51?
Would not think it would be that difficult.
Old Oct 13, 2014 | 11:59 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
  1. Jack car (I put it up so all 4 wheels were hanging.)
  2. Pop off the wheels
  3. pick a caliper and drive out the 2 chrome pins on the caliper. They will be pushed in from the outside of the caliper toward the center of the car
  4. remove the pad retaining clip (when the pins come out it'll probably fall to the floor)
  5. R/R pads
  6. hold retaining clip in place and insert the 2 chrome pins from the inside of the caliper toward the outside of the caliper Put 'em back like you found 'em
  7. replace wheel and torque to 100 lb ft
  8. Repeat for the other 3 calipers
Old Oct 13, 2014 | 12:42 PM
RCB1234's Avatar
RCB1234
  5. R/R pads
Thanks Eboggs!
Old Oct 13, 2014 | 01:27 PM
eboggs_jkvl
Moderator emeritus
It took longer to jack it up and pull the wheels than it did to swap out the pads.
One thing!!!!!!!! IMPORTANT. There is a thickness difference in the new pads. Your pedal will go down really low on the first pedal push. Pump up the pedal BEFORE you drive it!!!!!!!!!!!!!!!!!!!!!!
After the pedal is up, you're all set.
Elmer
Old Oct 13, 2014 | 03:55 PM
indy 28's Avatar
indy 28
Just had some Carbotech 1521 pads put on my Z51 (12K miles). Too early to appraise the dusting problem, but the brake screech and squeal noise is terrible during slow speed stop. This needs to improve soon, or back to the original pads
Old Oct 13, 2014 | 04:06 PM
eboggs_jkvl
Moderator emeritus
Interesting. I had a low groan at first at the "almost stopped" speed. Pretty much gone away but there definitely was no screech or squeal.
Elmer
Old Oct 13, 2014 | 06:43 PM
ENCT's Avatar
ENCT
  5. R/R pads
Thanks for the instructions, I just ordered a set.
Eric
Old Oct 13, 2014 | 08:38 PM
WKMCD's Avatar
WKMCD
Bed the new pads and all will be well. Ask me how I know.
Old Oct 13, 2014 | 08:44 PM
ENCT's Avatar
ENCT
I assume I should have the rotors cut? And how do you know?
Thanks,
Eric
Old Oct 13, 2014 | 08:50 PM
  #33
RedC7AZ's Avatar
RedC7AZ
Originally Posted by PaulB
I have used Ceramic Pads for my last several Corvettes. Question, On the C7 are the Brake Pads the same on Z51 and non Z51 Corvettes ... Thanks ...
Something is different, because I get very close to no brake dust with the Non Z51 pads front or rear.
Old Oct 13, 2014 | 08:54 PM
  #34
Supersonic 427's Avatar
Supersonic 427
The pads are different on the Z51! I like the fact that the NON Z51 has extremely low brake dust and the rotors don't rust!
Old Oct 13, 2014 | 09:00 PM
  #35
indy 28's Avatar
indy 28
I would have had them prebedded if needed, but Carbotech said not required or offered on the 1521's
Old Oct 14, 2014 | 09:26 AM
  #36
Carbotech Adam
Supporting Vendor
Did you clean your rotors up before putting them on?
Old Oct 14, 2014 | 09:28 AM
  #37
Carbotech Adam
Supporting Vendor
Also, try putting some heat in them.
To Brake dust!
  #38
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
I clean my wheels and after a few stops they have a fine brake dust. It makes no difference what product you use. I am going to Ceramic pads just to save my wheel wiping back.
Old Oct 14, 2014 | 09:30 AM
  #39
Bill17601's Avatar
Bill17601
AIR FORCE VETERAN
I find it hard to believe the rotors on your Corvette don't rust. Wash the car and leave them wet. see?
Old Oct 14, 2014 | 09:39 AM
  #40
Glen e's Avatar
Glen e
Its the discs that are diff, i belive, some special type metal that does not generate the brake dust from the pads. I can do 1000 miles (just did) and on my base wheels, the dust is not visible....
