2015 auto uncommanded downshifting
Old Oct 23, 2014 | 09:13 AM
767guy's Avatar
767guy
Default 2015 auto uncommanded downshifting
Just got the new machine and noticed when going down a steep hill as the car speeds up a light brake pressure is applied and the tranny starts downshifting.....conditions are; DRIVE(not manual),TOUR mode,cruise control OFF, shift paddles not touched.Any else see this with the new 8 speed auto tranny ?? tks
Old Oct 23, 2014 | 11:36 AM
Stakinjctd540's Avatar
Stakinjctd540
Navigator
I was in the Ozark mountains this past weekend and my 2015 also downshifted going down steep hills. Mine always seemed to downshift and maintain 3000 rpm under the same conditions as you described; I tried every mode except track, and the results were the same. I don't much like the downhill downshifting but I'm assuming it's some sort of safety feature; Big Brother is always looking out for us these days. But, it won't really be an issue for me, as so far it only occurs on really steep hills and there aren't any of those in my area. Hopefully, the tech-savvy forum members can tell us if this is normal behavior for the 2015 eight-speeds.
Old Oct 23, 2014 | 11:40 AM
dbdave's Avatar
dbdave
It's a truck thing. The trans is used in the pickups and Suburban/Tahoe and the equivalents in the GMC line.
Old Oct 23, 2014 | 11:54 AM
767guy's Avatar
767guy
Thanks for the info..sounds like my car is working as designed...not sure I like that feature. Leaving for Florida soon through KY andTN. Don't want all that downshifting so I'm going to try selecting MANUAL just before the downhills and see if it stays in the same gear...otherwise love the car
Old Oct 23, 2014 | 12:22 PM
C7Joy's Avatar
C7Joy
If it's a steep hill I often downshift my manual for engine braking. I'd rather avoid riding the brakes.
Old Oct 23, 2014 | 12:29 PM
Wolfmayhem's Avatar
Wolfmayhem
Did you have the cruise on? My other car will downshift with the cruise on to try and slow the car down to the set speed but it won't downshift if the cruise is off.
Old Oct 23, 2014 | 12:36 PM
kwickag's Avatar
kwickag
Different car CTS VSport, different transmission Asin 8 speed but it does the same thing so it must be in the programming.
Old Oct 23, 2014 | 12:40 PM
thrilled's Avatar
thrilled
Being you brought up the subject MANUAL.Whenever I slow down I downshift from A higher gear to a lower one til I'm stopped.I hardly use the brakes.I imagine more expense on gas.Some say it wears out the clutch.Been driving manuals for years.Never any clutch issues.
Sorry about change of subject.
Old Oct 23, 2014 | 12:45 PM
mpuzach's Avatar
mpuzach
As stated in the original post, cruise control is off.
Old Oct 23, 2014 | 05:07 PM
JoesC5's Avatar
JoesC5
I'm hurt. Really, really hurt that Big Brother doesn't' care about the safety of those of us that drive manual transmission cars. It's not fair that only the cars with automatics are safe to drive downhill.
Old Oct 23, 2014 | 05:22 PM
767guy's Avatar
767guy
Yes I agree , there are cases where the downshifting works well and with a manual trans you have complete control of when to down shift and by how much. The issue I'm having is the AUTOMATIC 8 speed tranny downshifts is all the time ( cruise control off) as soon as you touch the brakes even lightly going down hill it sometimes down***** by at least 2 gears so its making the decision rather than the driver....what I discoverd this afternoon coming home was just before starting down the grade I shifted the drive selector from D to M . In "M" the instrument cluster showed I was in 7th gear and as I went down the long hill the car started gaining speed and with very light brake pressure I was able to control speed and " NO UNCOMMANDED DOWNSHIFTING as in M the shift paddles are controling. This left me the option of contiuing with braking OR using the paddles to downshift maybe one gear or two but now I'm in control of it making the decision and by how much and when.....O.K. I admit it , I must be a "control freak "
Old Oct 23, 2014 | 05:29 PM
767guy's Avatar
767guy
Here is the thing...GM knows that you guys that drive 7 speed manual's are pretty co-ordinated and can upshift and down shift your way through thick and thin whereas old un-cordinated drivers like me need the Automatic to be safe BUT they give us those shift paddles so we can believe we too are real sports car drivers.....
Old Oct 23, 2014 | 06:00 PM
thrilled's Avatar
thrilled
It seems that GM more or less wants to control the car more than the driver
Old Oct 23, 2014 | 06:58 PM
Groovepusher Sly's Avatar
Groovepusher Sly
Default You Have To Train Your Transmission
There was an earlier thread about the A8 trans. In it there was a reference to a service bulletin (#14-07-30-001A - Information on Transmission Adaptive Functions) that when I went to read it downloaded to my desktop. It explains how you have to TRAIN your transmission.
"Some customers may comment on low mileage vehicles with automatic transmission that shift feel to be too firm (harsh) or may slip or flare. Customers should be advised that the transmission makes use of an adaptive function that will help to refine the shift feel while driving and improve shift quality.
The Hydra-Matic® 8-Speed RWD transmission utilizes a line pressure control system during upshifts to compensate for new transmission build variation as well as the normal wear of transmission components. The variation experience on a new and normal wear of the apply components within the transmission over time can cause shift time (the time required to apply a clutch) to be longer or shorter than desired.
In order to compensate for these changes, the transmission control module (TCM) adjusts the pressure commands to the various pressure control (PC) solenoids to maintain the originally calibrated shift timing. The automatic adjusting process is referred to as “adaptive learning” and it is used to ensure consistent shift feel plus increase transmission durability.
The TCM monitors the A/T input speed sensor (ISS) and the A/T output speed sensor (OSS) during commanded shifts to determine if a shift is occurring too fast (harsh) or too slow (soft) and adjusts the corresponding PC solenoid signal to maintain the set shift feel. The purpose of the adapt function is to automatically compensate the shift quality for the various vehicle shift control systems. The adapt function is a continuous process that will help to maintain optimal shift quality throughout the life of the vehicle."
It mentions 3-1, 2-1, and Power Downshifts.
The bulletin is two pages with a chart, so it might be worth checking out to see how to program your trans.
Hope this helps.
Sly
Old Oct 23, 2014 | 07:36 PM
767guy's Avatar
767guy
Hope this helps.
Sly
Thanks, good info.
Old Oct 23, 2014 | 07:47 PM
JoesC5's Avatar
JoesC5
Hope this helps.
Sly
I seem to remember that the A4 in my 1998 C5 had "adaptive learning" also, but it never down shifted going downhill to keep the car from "running away".
Old Oct 23, 2014 | 08:06 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
I am thinking that is why it is called an "automatic". It automatically shifts for you. If you want to manually shift, you need a manual transmission.
Old Oct 24, 2014 | 09:06 AM
Walt White Coupe's Avatar
Walt White Coupe
but If you want to manually shift, use the paddles.
Old Oct 24, 2014 | 09:22 AM
AFVETTE's Avatar
AFVETTE
Not really, just place it in "manual" mode.
Tom
To 2015 auto uncommanded downshifting
