Z51 spoiler fitment question
Hang on to it just like it is. It's definitely a rarity, probably the only one to leave the factory that way!
To be serious, somebody screwed up, there shouldn't be any threads showing. It's a lot of work to fix it, take it back to the dealer.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
I recall early on someone quoting a GM spokesperson saying there was a gap designed for proper aerodynamics! However my C7 built in September 2013 has no visible gaps. Just checked and can’t get a piece of paper in along any part of the Z51 spoiler!
Is your car a Z51 or does it have the ZF1 option? My question leading to, wondering if the spoiler was installed at the factory or was it installed at the dealer? Either way, as all the other posts indicated it isn't supposed to look like that.
I agree with all the above. Unfortunately to fix it the rear fascia will have to come off or at least loosened, so you can get to the nuts underneath, so it is not a quick DIY fix. Find some other C7 you can take a picture of (showing what it should look like, in case the dealer disagrees) and take it to the dealer to get it fixed.
OTOH that pic shows why the wing spoiler can't replace the Z51 spoiler. Nice to see.
Moderator
According to his profile, it is a "2015 C7 Z51".
Did some more messing around today and it appears that the outside bolts are completely free. I can pull the edges up on both sides at least an inch. Maybe the forget to put all four bolts on?
Anyways, I have a list of 6 things that need fixed and will be taking it in next week. Sucks because my '10 Grand Sport was nearly perfect albeit feeling cheap.
