Center Steering Wandering
Old Oct 26, 2014 | 03:08 PM
GTD_CORVETTE's Avatar
GTD_CORVETTE
4th Gear
Default Center Steering Wandering
My wife and I were the first to test drive a brand new 2014 (non-Z51) Stingray with the 6-speed automatic. We were impressed with how effortlessly the car accelerated to highway speed, and in particular with the spine-tingling feel and sound at startup. However, we found one characteristic troubling, namely that we needed to make constant small corrections to keep the car centered on smooth, straight concrete highway at 65 MPH.
This is a problem that we've never had with our 1997 Lexus ES300 or with our 2009 Honda S2000. Is this behavior characteristic of all Stingrays, or was there an alignment issue with the car we drove?
Old Oct 26, 2014 | 03:12 PM
Rand1993's Avatar
Rand1993
Mine was out of alignment from the factory and pulled to the right. Required constant steering input. Took it to a local tire company and paid for a front end alignment (didn't want to do the whole dealer thing). Been perfect since. 2LT non-Z51 5000 miles.
Old Oct 26, 2014 | 03:16 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
Agreed. It is not normal.
The only time I notice that sort of thing is our freeways here, in the right (and sometimes) center lanes, due to the groves in the road surface caused by studded tires and semis
Larry/car's Avatar
Larry/car
My C7 #22487 tracks straight at speeds up to 100 mph (highest speed attained to date).
Old Oct 26, 2014 | 03:19 PM
KenHorse's Avatar
KenHorse
Slacker
Old Oct 26, 2014 | 03:28 PM
mdiiulio's Avatar
mdiiulio
You need to take this to heart...
Old Oct 26, 2014 | 04:45 PM
Zymurgy's Avatar
Zymurgy
Moderator
It could be an alignment issue, or it could be the driver mode control setting. I find the steering to be "loose" and lacking good feedback in anything below the Sport setting.
Old Oct 26, 2014 | 09:15 PM
GTD_CORVETTE
4th Gear
Unfortunately we so excited about our unexpected opportunity to finally drive the C7 that we neglected trying out the different driving modes. Also, the drive was too short. My wife described the car as having a "floaty" feeling while driving on concrete slab, whereas I simply found myself continually making fine corrections to keep the car pointed in a straight line. We definitely want to do another test drive where we can compare the "comfort" and "sport" modes that we would expect to use most of the time.
Old Oct 26, 2014 | 09:23 PM
-CM-'s Avatar
-CM-
It has been reported here that the steering in Tour mode feels "floaty." Fortunately, you have a choice to set the steering I mode separately from the driving mode, if desired. I like it set to Sport mode.
Also, concrete road surfaces are typically grooved, and the wide tires tend to track in them, likely contributing to what you felt.
Old Oct 26, 2014 | 09:42 PM
GTD_CORVETTE
4th Gear
We were on CA Hwy 29 just north of Lakeport. I didn't think that the road was grooved, but I could be wrong. My wife appreciates your reference to other forum reports, and now feels vindicated in her use of the word "floaty"! Anyway, we're anxious for another test drive where we can try out the sport mode, or even change the steering setting from its default value while in comfort mode.
Old Oct 26, 2014 | 11:28 PM
hankman's Avatar
hankman
Mine drives so straight, it feels like its on tracks, no wondering or correcting....
Old Oct 27, 2014 | 01:04 AM
WelderGuy's Avatar
WelderGuy
I've test driven four C7s, and all went straight ahead without needing correction. I'd say it's an alignment problem.
Old Oct 27, 2014 | 01:32 PM
ocjim's Avatar
ocjim
Mine too, went to dealer free alignment, problem gone.
Old Oct 27, 2014 | 03:23 PM
NavyVet's Avatar
NavyVet
My first impression test driving ours before buying was the same. Changed the steering setting under "Tour" to Sport and all is well.
For others, Friday when we bought ours, salesman came back from wife's test drive and said she hit 110 on the freeway on ramp. She is really liking it.
Old Oct 27, 2014 | 03:32 PM
Mike Mercury's Avatar
Mike Mercury
<<<@!1!@>>>
is it tramlining ?
<<<@!2!@>>>
also:
http://en.wikipedia.org/wiki/Tramlining
Old Oct 27, 2014 | 07:29 PM
GTD_CORVETTE
4th Gear
Originally Posted by Mike Mercury
<<<@!1!@>>>
is it tramlining ?
<<<@!2!@>>>
also:
Tramlining - Wikipedia, the free encyclopedia
It's possible, but I didn't think there were any grooves for the tires to follow - but I could be wrong. Thanks for the link in any case!
Old Oct 28, 2014 | 03:47 AM
WelderGuy's Avatar
WelderGuy
Sounds like the toe-in adjustment is off http://www.townfairtire.com/wheel-al...oe-alignments/
The important part:
"Toe-in also provides increased stability because it discourages turning. If your vehicle has the proper amount of toe you should experience ideal straight line stability..."
Old Oct 28, 2014 | 07:18 AM
aj98's Avatar
aj98
Agree....steering feels loose/floaty in Weather, Eco, and Touring.
Fat tires will track the seams and grooves in the road, so that could be a contributing factor.
But checking the alignment on all 4 wheels is a lot cheaper than replacing the tires.
Old Oct 28, 2014 | 10:42 AM
chas70's Avatar
chas70
I have had this experience also. Found it to be grooves in the road from studded tires. I wasn't sure that is what it was until I was driving my truck on a rainy day and could see the grooves because of the water setting in them. Even on dry pavement, if I don't keep centered in the groove, it will wander because of the wide tires.
To Center Steering Wandering
