Seat Settings
Thanx.
Thanx.
If you haven't had tons of responses it's because you can find it in the "search" section under memory seats or something close to that. It's been discussed many times here.
Good luck.
Good luck.
Thanx.
I’m still convince (sic) they farmed out the seat recall software to someone overseas who never drove a car! Why the “fix” isn’t what we had in the C6 is beyond me!
Speedy Gonzales Uses The Seat Recall When The Door Opens!
Choose "At Ignition On" instead of "On Driver Door Open." Now it will move the seat to your programmed position after you get in when you hit the Start button.
Get in car, press and release the START button. Whichever memory is linked to the FOB you're currently carrying will be recalled. Once your seat has moved into position, step on clutch pedal and press START again to start the car.
See? Easy peasy.....
I know I am purposely being funny about it and yes since I have been doing two things at once for over a year I don’t feel the need to change. Granted it is a minor point that while I would be reaching to push the start button (without being able to start since the clutch was not depressed) I could not use that hand to pull the seat belt over to buckle it while a finger on my left hand holds the seat recall button, which is what I do now-I multitask!!
I do understand why folks like the new software, it’s better than it was but why they just didn’t make it like the C6 is beyond me! Get in, push the button once, and buckle the belt while it was proceeding to the proper position. Also still have not heard any logic that would make anyone want to have the seat go to the driving position from the exit position when you opened the door! Why did it get programed that way?
Don't get me wrong, I love the car and the minor issues, like having the door open to latch the hatch and the seat memory are minor and I have easy workarounds! Wish I could say the same for all my MS and other software!
Get in car, press and release START, buckle up and by the time I'm done buckling up, the seat is where it needs to be to start the car. Really, it ain't no thang.....
Seriously, I think some folks bitch just to bitch......
Thanx.
